User Tag List
Thanks Thanks:  3
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Senior Member Harquebus's Avatar
    Join Date
    Jun 2009
    Location
    Eastern TN
    Posts
    200
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Satio View Post
    ...On the bottom component of the connecting rod, is there a "front" "back" or "left" "right" to this or does it matter?
    YES! The con rod and rod cap is marked and oriented in a certain way and should be properly oriented upon reassembly.
    On my photo, you can see twin casting notches on the con rod and rod cap and that they are on the side of the block NOT facing the cam gear. Mine is a 130000 series 5 horse.
    Make sure you also orient the oil dipper (if it's the asymmetrical style) so it does not make contact with the block during any part of its revolution. That's a racing/performance oil dipper by the way.
    The green slime is engine assembly lube.
  2. #12
    Junior Member
    Join Date
    Nov 2017
    Location
    Arlington, Texas
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Got it.
    Thank you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
