User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 10 of 10
  1. #1
    Senior Member red baron's Avatar
    Join Date
    Mar 2017
    Location
    maine
    Posts
    312
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    parts interchangability
    I have a flat head 4hp, what parts will interchange with a 5hp? or what is available for performance parts for this motor?
  2. #2
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    12,290
    Mentioned
    69 Post(s)
    Tagged
    2 Thread(s)
    Rides
    I'm not real familiar with the 4hp Briggs , so I don't know if 5hp parts will interchange or not. I know people who have used the 4hp head on there 5hp Briggs because it is a better compression head .
    But you can get a better exhaust system like a header , do some porting on the intake and exhaust ports and even throw a little more timing in it. Free flowing air filter will help to.
    Lil Indian, Ruttman, DB30, Warrior, lil Bill, EZ Rider, Savage SSC , Powell, BONANZA
  3. #3
    Join Date
    Mar 2017
    Location
    maine
    Posts
    312
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thank you for the tips.
  4. #4
    roccosbike's Avatar
    Join Date
    Oct 2010
    Location
    Mundelein,IL
    Posts
    4,340
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You can put a 5hp crank in it and it will give it a little more stroke and give you a way to put a billet rod in it (must use 5hp rod with 5hp crank). Oh and everything else that fits a 5hp briggs will fit your 4hp accept the piston unless you bore it then everything will interchange.
    Basically the crank con rod and piston are different, hope this helps you.
    Bonanza brotherhood, Chicago
  5. Thanks mrpat thanked for this post
  6. #5
    Member
    Join Date
    Oct 2017
    Location
    South Louisiana
    Posts
    75
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Do you have the model number for that 4 HP ??
  7. #6
    Senior Member
    Join Date
    Jan 2008
    Location
    homewood junction,pa
    Posts
    323
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If its the old one,looks like a flathead 5hp, not much interchanges. Block,crank,rod,piston,head,flywheel all different.5hp crank is too wide to fit into Block without machine work. Piston is smaller diameter.
    If you hopping up,better money spend on 5hp.if you really like the way the 4hp looks,swap tins....
  8. #7
    Senior Member The.MiniTard's Avatar
    Join Date
    Nov 2017
    Location
    California
    Posts
    315
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have a 4hp and a 5hp. Internals do not interchange, different wrist pin sizes, and journal dia.
  9. #8
    Senior Member tecumseh power's Avatar
    Join Date
    Nov 2014
    Location
    On the Reservation
    Posts
    153
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    There is a 3HP based 4HP Briggs engine that they made in the 80's. I've only seen a few of them it was like a big bore 3 HP engine that nothing interchanged with the 5HP engines.
    The other 4HP as others have mentioned looks like 5HP, but is a good bit different. We used to use the heads on 5HP engines as others have said.
  10. #9
    roccosbike's Avatar
    Join Date
    Oct 2010
    Location
    Mundelein,IL
    Posts
    4,340
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by The.MiniTard View Post
    It depends on what year engines your working with and yes there are parts that interchange.
  11. #10
    Join Date
    Nov 2017
    Location
    California
    Posts
    315
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by roccosbike View Post
    Guess ive got some work to do then. i have a 5hp with a messed up valve guide and a raggedy eyebrow cut job.....and a beautiful 4hp block that has a grinded up crank....ill see if the cranks interchange. Both are 70's era flathead Briggs
Posting Permissions
  • You may not post replies
  • You may not edit your posts
