User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
Thread: 67 Briggs Help
  1. #1
    Junior Member
    Join Date
    Jun 2018
    Location
    Dallas, TX
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    67 Briggs Help
    Im new to this game and still trying to learn engines so here is my dumba** question. What is this "second crankshaft" coming out of my 130202 BnS?? from what ive found so far its for the reverse but how do I remove it or is there a way to utilize it on my bonanza?
  2. Thanks Jjtwospeed thanked for this post
  3. #2
    Join Date
    Apr 2014
    Location
    MA
    Posts
    2,780
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Usually this is used on snowblowers for reverse gear. I have seen some people cut the shaft, personally I would get a single pto side cover, it will not come with that second hole in the cover and you can use regular camshaft.
    If you cut it just remember that the shaft will still spin which could be dangerous
  4. #3
    Senior Member Harquebus's Avatar
    Join Date
    Jun 2009
    Location
    Eastern TN
    Posts
    252
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Also used on those nice garden tillers with reverse, like the Troy-Bilt Pony.
    I agree with massacre on the get-a-single-pto sump cover and a standard cam gear idea. Check fleabay or wherever you like, they should be easy to find and for low cost.
    For search terms, the nomenclature is:
    Cover Assy-crankcase, part# 297602
    Gear-cam, part# 212733
  5. #4
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,803
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Going with a different case and cam is the easy way . Or different motor may be some one would swap ya motors ?
  6. #5
    Junior Member
    Join Date
    Jun 2018
    Location
    Dallas, TX
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    thank you for everyones input... I think im going to cut the shaft off, it seems like the easiest solution and im pretty sure the clutch I have will cover that area up so it shouldn't cause any issues.
  7. #6
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    8,986
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Adonis View Post
    Yes, the clutch does cover it. Be aware that you need enough shaft exposed to allow the shaft seal to continue to work, and that if you generate too much heat while cutting it, you'll damage the seal too.
    You could just leave it alone and see if it impedes the chain. I've had this same situation on a Cat mini bike, and the clutch and the chain cleared that shaft just fine. You could only see that shaft if you looked for it.
  8. #7
    Junior Member
    Join Date
    Jun 2018
    Location
    Dallas, TX
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Havasu Dave View Post
    Thanks for your input Havasu Dave, the shaft is too long and I cant place the clutch on properly without cutting it off, but I will leave a good half inch or so on it so I don't damage the seal.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
