User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
  1. #1
    Junior Member
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Here's the new Flathead
    I had some time to start to dig in today. It looks a lot better than I anticipated despite still being pretty cruddy. I think this will clean up nicely and be ok. I can spin the intake valve barely. It takes a good amount of trying, but I'll get them out, lap them and grind if needed. I didn't push the piston all the way down but from what I could see the cylinder looks good. No crosshatch is discernible but I also don't see any scoring. I broke the starter clutch open trying to get it off. It was stuck much tighter than the flywheel. I'm not sure if they can be reassembled or not but I'll look later.
    Does anyone have a trick to getting the valve springs put back on without buying the special valve spring compressor tool?
  2. Thanks TWM1963 thanked for this post
  3. #2
    Junior Member
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nevermind about the springs. I saw a YouTube of a guy using trusty old zip ties. Why didnít I think of that. Zip ties can do anything! :)
  4. Thanks TWM1963 thanked for this post
  5. #3
    Sport King Eric's Avatar
    Join Date
    Jan 2015
    Location
    Harrison twp Michigan
    Posts
    570
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yes I agree.. Zip Ties are one of the best inventions ever!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
