User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 1 of 1
  1. #1
    Member
    Join Date
    Apr 2018
    Location
    Central MA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Broncco converted to trike
    1960's Broncco minibike converted to a trike in the 70's with what appears to be a go kart rear end. The picture is what it looked like before I tore the rear end down to replace the axle and bearings. I tore the rear end apart and got a whole bunch of other projects so this isn't top priority now. Comes with brand new seat, new axle, new rear wheels and tire, spare used front wheel and tire, brand new china torque converter, new bearings for the axle, new brake caliper, chain, Tecumseh hs50 engine without recoil or muffler, original gas tank (needs work) and round tank off an old Clinton engine. Frame is very straight and the conversion looks well done. Also has vintage split sprocket on the rear in good shape. The worst part of it is the brush paint job. Asking $200, have quite a bit more than that in it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
