User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Join Date
    Jun 2016
    Location
    Portersville,PA
    Posts
    107
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Wipe the belt and pulleys clean and dry. Rub baby powder on the sides of the belt, that will make it hook up smooth. This worked great for my belt drive mini dozer!
  2. Thanks manchester1 thanked for this post
  3. #12
    manchester1's Avatar
    Join Date
    Jun 2010
    Location
    burlington, nj, Jim Thorpe, PA
    Posts
    13,946
    Mentioned
    46 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Sounds like some of the welds could of broke loose on the engine plate.
    "CLONANZA CLAN"
  4. #13
    Senior Member BBQJOE's Avatar
    Join Date
    Jul 2016
    Location
    Arizona
    Posts
    426
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have a flywheel that I'm certain is out of balance. I had it on two different engines, and my bike wants to rattle to pieces at certain RPMs.
    Believe it or don't, I've taken it to 3 machine shops trying to get it balanced.
    All 3 said the same thing, "I don't have a mandrel that'll fit it."
    To which I replied to all three, "Hey, I got an idea, let's call a real machine shop!!!"
  5. #14
    Senior Member FirePowerMinis's Avatar
    Join Date
    Oct 2012
    Location
    Flint, MI
    Posts
    740
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I've noticed the same thing on a buddy's single-speed DB-P212. I think it could be a few things:
    Added stroke and bore over the Honda 196 may add some shakes.
    Carb not made to pull a load through low-mid rev range.
    Balance factor, also not suited for low-revs, high-load.
    Light duty engine plate and chassis may be transmitting more, normal movement.
    I was discussing the odd light-crank, heavy-flywheel setup with interweb pals recently too. Great for an engine that may strike an object while mowing, so the f/w can maintain momentum by key shearing, but not what the typical high-rev hotrod desires. I'm hoping to adapt a motorcycle-type full-circle crank and run a 3.5" sub-1lb f/w with a curved CDI and lighting coil. Maybe even chain-drive the cam so the engine can run "backward". leaning forward, eliminating the fan and shroud for free-breeze. Honda G400 ran cam by chain, as do a quadrillion other varieties of engine outside the ditch-pump world.
  6. #15
    Senior Member Evil Tweety Bird's Avatar
    Join Date
    Sep 2016
    Location
    Lakeland florida
    Posts
    235
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Umm, may sound silly but any chance the bell on the clutch is slightly bent/dinged/deformed?
    Would explain teeth rattling low rpm shake. Clutch shoes riding back and forth over a high spot on the bell.
    Once it is able to lock up, problem would disappear.
  7. #16
    Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    1,661
    Mentioned
    24 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You say you used that pmr adjustable plate ..Try c-clamping the frame and the pmr plates together on back and front test if tight or helps...Never heard of anyone having to run bolts all the way thru both the adjuster plate and frames plate basically using it as a riser instead of its intended purpose..unclear if it is magnifying low rpm "chatter" on take off....I'm thinking out loud..my last resort thought...
  8. #17
    Senior Member
    Join Date
    Feb 2017
    Location
    Ohio
    Posts
    373
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Not silly at all. Step 1 in the troubleshooting process here should be the clutch.
  9. #18
    Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    1,661
    Mentioned
    24 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by SAS289 View Post
    Yep..if was me I'd sit on the bike and engage clutch with brakes on a little,to scuff the shoes good.. then take it apart and clean and sand the bell..or try another clutch
  10. #19
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,468
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    250 pounds is alot weight to run through stock OEM clutch. i would chatter too if i had to push that much weight when taking off. i have also heard of that same problem with the stock 2.5/2.8hp doodlebug bikes and seen guys replace the stock clutch's with a max clutch with just a slightly higher stall clutch. not saying this will fix your problem with your clone/honda motor.
    i got couple stock doodlebugs for the kids to ride and they chatter bad when taking off with me on it(#175). but with the kids on it....not so bad. just no weight for the clutch to fight with when a #80-#100 kid on it.
    you did say something about replacing the clutch soon. interesting to see what happens?
    torque converter would be better...... it's just more money$$$
    goodluck.......
  11. #20
    Senior Member KB2ROCKET's Avatar
    Join Date
    Mar 2007
    Location
    relax its only a minibike
    Posts
    3,515
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Borrow a different clutch before taking yours apart
Posting Permissions
  • You may not post replies
  • You may not edit your posts
