User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,017
    Mentioned
    9 Post(s)
    Tagged
    0 Thread(s)
    Rides
    That is an external CDI It should not have wiring other than a tab on it connected to the kill switch. When you ground the tab it gets shut off. If the gap is correct then just replace the CDI unit, they do go bad.
    Ole
  2. Thanks FOMOGO thanked for this post
  3. #12
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    8,101
    Mentioned
    9 Post(s)
    Tagged
    0 Thread(s)
    Rides
    A word on magnetos and flywheels and rust. The presence of normal rust does not impede "spark." The system works on induction, not electrical continuity. Many of the small engine manuals actually address this.
    The points however are a different story, and are quickly affected by higher resistance.
    The reason for using a spark tester is because the spark acts differently under compression, than it does with a spark plug sitting on an engine. You can have a good spark on a plug sitting out of the bore and grounded, yet have a weak magneto, insufficient for firing the plug under pressure.
    From your description, it seems to indicate you have either a bad magneto, or a bad plug wire. "Electrode Open" means that the electrode on your plug is not electrically connected to the stud on top of the plug. I've never seen this. Double check your connections on the tester, and definitely compare a known engine with the troubled engine.
    You should also specify in this post which type of ignition system you are using, points, or magnetron (solid state). Note that these engines will generate an adequate spark at a magneto gap from .010 to .040 roughly, even covered in rust. You have a bad magneto, a bad wire, or points are malfunctioning.
    Just a garage hack sitting on a plastic bucket armed with an angle grinder.
  4. Thanks FOMOGO thanked for this post
  5. #13
    Senior Member drenchedgremlin's Avatar
    Join Date
    Mar 2010
    Location
    NV
    Posts
    141
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Havasu Dave View Post
    I will double check my tester soon even though I already did more than once. I know nothing is wrong with the plug when I tested it on other motors as well. So I guess I should buy a new coil. I may be wrong, but if I buy a new coil, would this fix my magneto or wire problem, if that is what the problem is?
  6. #14
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,017
    Mentioned
    9 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You dont have a magneto! Your picture shows external cdi. No points just a ground tab like I posted above.
    Ole
  7. #15
    Senior Member DeadPixel's Avatar
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    273
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Does this motor have an internal low oil switch?
  8. #16
    Join Date
    Mar 2010
    Location
    NV
    Posts
    141
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by DeadPixel View Post
    Not sure exactly, how would I tell?
  9. #17
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    273
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    There will be a wire coming out of the block for it. It is connected to your ignition system and shuts it down if the oil level is too low. I have had my mower cut out and seam like it was missing due to low oil. I am sure if the switch was bad it could cause problems that looked like an ignition issue. I believe you can just disconnect it.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
