User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Building HS40
  1. #11
    Junior Member
    Join Date
    Apr 2018
    Location
    Crossville Tennessee
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    https://www.ebay.com/itm/Carb-50cc-7...-/332407292233
    Its shipped super fast nice quality has changeable jets and runs great.
  2. #12
    Senior Member delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,072
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    DELRAY
    that all depends on the cam you plan on using. can put you in the pall bark.
    for example: if you just want to stay with a stock cam ,but still want to rev it little higher and it will when engine is setup correct and do not forget to use a billet rod. the old style stock hs-rods will break.
    i would go with the animal retainers and keepers and animal 16 pound spring. all this will give you the correct valve spring setup.
    correction on this if you where doing a flathead hs-40 motor. use dynocams retainers for flathead briggs . you have to machine little inner step of to clear the animal spring. this will give you the correct spring height (.800)
    left animal and center dynocam
    left dynocams and on the right animal retainer
    also note on the keepers where the locks are at. I have seen animal's work before,but never seen where the locks where position. here is a picture of animal's that did have the correct height on a hs-40 flathead.
  3. #13
    Junior Member
    Join Date
    Apr 2018
    Location
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Well got the ol bike going today new torque converter on and new jack shaft still got to put the timing advance key in but as you can see it’s got some torque!
  4. #14
    Join Date
    Apr 2014
    Location
    MA
    Posts
    2,828
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Awesome
  5. #15
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,072
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    same kind of bike i learn on.....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
