User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 2 of 2
  1. #1
    Junior Member
    Join Date
    May 2017
    Location
    55106
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Vegas 460 piston rings order HELP
    I'm assembling a Vegas carts 460, I'm not sure which compression ring goes on top and which direction. One ring has an "0" stamped on it and both sides seem to be the same shape with sharp corners. The other ring says NH or HN on it with slightly angled corners on both sides. Which goes on top? Thanks!!
  2. #2
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    3,232
    Mentioned
    60 Post(s)
    Tagged
    0 Thread(s)
    Rides
    In an automotive application the markings go up. Don't know if it would apply to your application as well.
    Typically if a ring is direction specific it is because it has a beveled out edge that has the sharp edge UP for compression and cylinder seal.
    "A day without laughter is a day wasted." - Charlie Chaplin
    If stupid could fly you would be a jet.
    Duct tape cant fix stupid but it can muffle the sound.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
