User Tag List
Thanks Thanks:  3
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Junior Member
    Join Date
    Oct 2018
    Location
    Los Angeles
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    CT200U - Increase Top Speed? 60 Tooth Rear Sprocket?
    I've got a stock CT200U. I clocked it at around 21-22 mph this weekend. I'd like to get it up to 28-30mph with the easiest mods possible. I am not as interested in increasing low end torque as much but I also don't want to exchange a ton of it for top speed. I also don't want to remove the governor, as I'd prefer to keep the engines RPMs safe to extend longevity.
    Any ideas on how to increase my top speed by 8mph? Will a 60 tooth rear sprocket give me a speed increase? I saw a video on Red Beard's garage where he added a 60 tooth rear sprocket and claimed it gave him more torque and more top speed. But he also had the high performance engine mods done to the bike as well.
  2. #2
    Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    2,075
    Mentioned
    35 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Burris Racing Jackshaft Calculator .. https://www.bmikarts.com/Go-Kart-Gea...eed-Calculator . . these may help. A smaller sprocket on rear gives more top end. A larger like the 60t will lower top speed alot maybe to 15 mph
  3. #3
    Senior Member TheDullCarbide's Avatar
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    799
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by robotfist View Post
    I think you missed that he had a Torque Converter. With a clutch, there is no way to gain both torque AND speed by changing gears. It is all a trade-off.
    Now I will add that a torque converter swap is pretty easy with the OMB kit and it will give gains on bottom AND top end, but it is much more expensive than simply changing a sprocket.
  4. #4
    Senior Member Bonanza Bryan's Avatar
    Join Date
    Dec 2009
    Location
    Petaluma, California
    Posts
    3,083
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I would spend the money and get a 30 series tav along with a stage 1 performance kit with 18lb valve springs that will get you to where you want to be and your bike will ride much better with the tav
  5. #5
    Junior Member
    Join Date
    Oct 2018
    Location
    Los Angeles
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Iíve been debating getting the torque converter but I donít know a lot about them. I primarily ride this bike out in the desert near Joshua Tree down in SoCal. So itís very sandy and some of the dry lake beds I ride on are dusty and have a fine, talc like powder. Since a TAV is belt driven, would this be an issue in that type of environment? Just wondering if Iíd end up with the TAV belt constantly slipping on me.
  6. #6
    Join Date
    Dec 2009
    Location
    Posts
    3,083
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I would think you’d be fine just be sure to run the cover on the tav
  7. #7
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    799
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I’ve been debating getting the torque converter but I don’t know a lot about them. I primarily ride this bike out in the desert near Joshua Tree down in SoCal. So it’s very sandy and some of the dry lake beds I ride on are dusty and have a fine, talc like powder. Since a TAV is belt driven, would this be an issue in that type of environment? Just wondering if I’d end up with the TAV belt constantly slipping on me.
    I would worry more about sand getting into the garter weights and driver hub than on the belt. But still, with a cover and some good maintenance you'll be fine. If you can afford it, get the TAV.
  8. #8
    Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    2,075
    Mentioned
    35 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I wouild also say a tav is best..your riding area seem air filter clogging will be a big issue i reccomend a old sock over filter ..something you can shake out to protect filter..there are many vids on YouTube to put a tav on..iv'e done it but some people have a different opinon on how... You need to see what size the crankshaft because newer ct200 has 16mm older 3/4" to get right tav..good luck
  9. #9
    Senior Member DeadPixel's Avatar
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    540
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    My bike is hitting abut 30+ right now. The governor is bypassed. It is limiting my RPMs to a little over 5K at the moment. I have a billet rod, GX160 aluminum flywheel and 22LB springs and a few other mods. I cut some coils out of the return spring to get the extra RPM but you need the rod and flywheel if you do this. If your just looking for a little speed I would do the rod, GX160 flywheel, GX140 valve springs and throw in a 31 jet to slightly richen up the fuel mixture just a little cuz the carbs are slightly lean usually as they are. I would run the GX140 springs over the normal 18s cuz there just a little lighter and are just insurance cuz you will be running the motor to the limit of the stock springs. You cant run any more than stock lift with the 140 springs and would only run them with a stock cam but will have the least amount of wear on the cam out of any stiffer spring you could get.
    Your best bang for the buck would be a torque converter but you need to raise motor and some times cut the cross bar that holds the chain guard. There is a 38 tooth sprocket on the market but it would sacrifice your bottom end torque and would not run it unless you had a torque converter or were only running on pavement. While you have the motor apart I would recommend putting a flat top piston in the motor. I like to do this to stock motors when I pull them apart. Its only $10 and an easy mod. If you motor is not new though I would also get rings and hone the cylinder when you install it. I have used the old rings just fine but I recommend doing it the right way lol.
    The rod is around $60 the flywheel is around $40 springs about $8 to $10 and a gasket kit $10. It will not effect how the bike feels and will add your top speed your after. If you do plan on later fully removing the governor I would swap to 18# springs over the GX140s. I have 22LB springs in my motor cuz I am installing ratio rockers. The 18s and GX140s cant handle them. But unless your running ratio rockers or a high lift or the cam recommends them there over kill.
    I know you don't want to remove the governor but getting the above parts and bypassing the governor will give you the performance your after, allow it to live with the extra RPMs and set you up for future mods if you decide in the future. With all this said though the torque converter is your best bang for buck and will add low end power and more top speed than the above mods.
  10. #10
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    9,239
    Mentioned
    29 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Agree with most of the comments above. Sand absolutely sucks down torque. Eats it for breakfast. I wouldn't waste my time and money on a sprocket change for the sole purpose of gaining top end. You WILL lose torque to gain top speed.
    A quality torque converter is going to make this a much better bike, and exactly what you need for desert riding.
    Sand does a lot less damage to a TC than it does to a chain. The guys who off road a lot on two wheels are removing their chains and soaking them in solvent after every ride to remove the grit stuck to the lubricant.
    Sand also kills the bushing on centrifugal clutches. Quickly.
    If I was going to chose between engine modifications or adding a TC, I'd go with the TC. You can upgrade the engine later.
  11. Thanks TheDullCarbide thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
