User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 85
  1. #21
    Senior Member jeep2003's Avatar
    Join Date
    Oct 2006
    Location
    Vestal NY
    Posts
    7,276
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    well iv got almost all the fabrication done I wasnt a big fan of where i had the tail lights positioned so i cut the mounts off and am lowering them down a bit. But iv got it all taken apart now so i can start cleaning it up and get it ready for paint and all. Im not sure if I should do the handlebars body color or something else like a silver
  2. #22
    Docdc's Avatar
    Join Date
    Jul 2013
    Location
    NE Ohio
    Posts
    2,336
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Maybe a complimentary color? Maybe if you do a pastel type 1950's color on the body, a cream color handlebar?? Good question Jeep.
    Doc
  3. #23
    Join Date
    Oct 2006
    Location
    Vestal NY
    Posts
    7,276
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    well the wheels and grips are off white so I could change the grips and do the bars white but I think a gray or silver would work better. too bad the chrome is long gone. i may do a similar color or maybe even the same color as my fat bike and the hammered gray went great with that. I have a few pastel colors to pick from too. Im sure Ill end up painting it two or three times before I land on a winner lol
  4. #24
    SimpleTom's Avatar
    Join Date
    Sep 2009
    Location
    Muskego, WI
    Posts
    6,592
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by jeep2003 View Post
    The General Appliance Alliance
    WWW.MINIBIKEMANIAC.COM Mini Bike Maniac T-Shirts and Decals
  5. #25
    Join Date
    Oct 2006
    Location
    Vestal NY
    Posts
    7,276
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I slapped a bunch of bondo on it today. I used jb water weld on the seams of the tank. i figure a nice security layer couldnt hurt. its suposed to be good for gas and i had lots of leftover from last weekend when i had to fix a cracked fish pond. Anyhow the body work will be a nice change of pace from all the metal work iv been doing between this and the scooter. I sprayed the handlebars hammered gray. I think it should look good with whatever color i end up with
  6. #26
    Join Date
    Oct 2006
    Location
    Vestal NY
    Posts
    7,276
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Im working on the body work now its going fast iv already got the tank and fenders nearly done. Then Iv got to test run the engine I dont even know if its a runner it had some debris in the mouth of the carb and the plug wire was cut. These engines are usually pretty good runners so im not too worried. I have a couple other carbs I can swap out if I have to
  7. #27
    Junior Member MiniFatTire's Avatar
    Join Date
    Nov 2015
    Location
    Torrance, Ca
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    It is looking great so far, very nice fab and bodywork skills my good man, I can't wait to see the finished product!
  8. #28
    Senior Member Twid's Avatar
    Join Date
    Aug 2015
    Location
    Oakland Calif
    Posts
    1,482
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    hell yeah!
  9. #29
    Join Date
    Oct 2006
    Location
    Vestal NY
    Posts
    7,276
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks guys I got the engine running today! It had no spark. the points had continuity at at all times. I thought it must be the kill switch wire or coil or condensor but when i unhooked them it was still there. So i cleaned the points and that fixed it. Aint that the strangest thing youve ever heard? anyway I had to clean the carb a bit and put the muffler on to get it to run right. Seems good now so i can go ahead with the cleaning process
  10. #30
    Join Date
    Oct 2006
    Location
    Vestal NY
    Posts
    7,276
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I got it painted today while the weather is nice. The first coat didnt go that great it was too thick coming out of the gun. So it was rough and i ran out of paint anyway. So i sanded it smooth and hit it again the second coat went well. At the end I thought my gun was clogging up or running out. turns out the compressor wasnt turned on lol. but it came out good. I wet sanded it a bit so tomorrow ill do a light coat of clear and start puting it together again. no pics today
Posting Permissions
  • You may not post replies
  • You may not edit your posts
