User Tag List
Thanks Thanks:  4
Likes Likes:  0
Dislikes Dislikes:  0
Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 88
  1. #31
    trinik7597's Avatar
    Join Date
    May 2013
    Location
    pine plains n.y.
    Posts
    5,739
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You have a Kean eye ole !!! Two of those heads are for big bore motors .. one for a 2.835 hemi and another for a 3" standard predator . I love what you are doing on your build !!! It's all in the detail .. a point that is very over looked ..
  2. #32
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,301
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    ole4, 26mm molkrt carb you are going to use. does that one take the same style jets as a mikuni carb.
  3. #33
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,110
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I dont know but when I get to the carbs ill check and post pi tures.
    Ole
  4. #34
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,110
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Well not that the short block is complete time to start on the heads, This is the first of three heads I will be adding 32mm valve and porting.
    Here is before and after enlarging the seat pocket.
    Ole
  5. #35
    Senior Member KMC3420's Avatar
    Join Date
    Oct 2015
    Location
    Arkansas
    Posts
    876
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Awesome job on this. Gonna be some big flowing heads. You gonna keep your compression low enough to run pump gas?
  6. #36
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,110
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    they will all be different compression's. One will be high I never had a detonation issue but there is a motorcycle dealer nearby that sells VP gas in 5 gallon cans if I have issues.
    Ole
  7. #37
    trinik7597's Avatar
    Join Date
    May 2013
    Location
    pine plains n.y.
    Posts
    5,739
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I run some pretty high comp. Gassers !!
  8. #38
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,110
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Were you able to use 93 oct pump gas?
    Ole
  9. #39
    trinik7597's Avatar
    Join Date
    May 2013
    Location
    pine plains n.y.
    Posts
    5,739
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yup 93 pump gas is what I am running in them
  10. #40
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,110
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Just finished cutting the 32mm counterbore on the 14cc head, two down one to go.
    To install the seats I will have to heat the head on a hotplate while the installation tool sits in the freezer. The driver fits on a pilot so that the seat goes into the counterbore straight. Some pics of the cylinder head toolkit, the driver with 28 and 32mm adapters and how it sits on the pilot which is inserted in the valve guide.
    Ole
Posting Permissions
  • You may not post replies
  • You may not edit your posts
