User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Page 8 of 8 FirstFirst 12345678
Results 71 to 73 of 73
  1. #71
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,064
    Mentioned
    11 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Mounted it on the test stand and did a quick fire with starting fluid man the dam thing is loud! This is the 14cc head (now 16cc) and the extra compression really gives it a crackle. I am thinking about mounting an alternator on the test stand and getting some high wattage resistors with some switches to make it a variable load so I could do some break in on the stand. I am figuring a 100 watt alternator under full load would take about 4HP to run it. I would not load it that much but it would at least allow more cylinder pressure under load to help seat the rings. Has anyone tried it?? I am also working on the next 18cc head. I have installed the 32mm seat and am now deshrouding on the mill as it does a much neater job that I have been able to do with the hand grinder.
    Ole
  2. #72
    Join Date
    Aug 2016
    Location
    White Lake , Michigan
    Posts
    1,330
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I'm curious why you have the crankcase vent and valve cover vent connected to each other. Is that to seat the rings or something like that?
    Danford1
  3. #73
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,064
    Mentioned
    11 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I am just adding a crankcase vent to the top of the valcover to be near the vent exit and to mist the roller rockers.
    Ole
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
