User Tag List
Thanks Thanks:  16
Likes Likes:  0
Dislikes Dislikes:  0
Page 6 of 6 FirstFirst 123456
Results 51 to 55 of 55
  1. #51
    Senior Member TheDullCarbide's Avatar
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    313
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Moto Walt View Post
    You better remove the governor, what is this going on? I'm curious now ... What needs to only do 4500rpm but needs ratio rocker arms?
    I wouldn't buy a single part for an engine I was trying to get to do 4500 for a long time besides MAYBE a rod and definitely some valve springs.
    I'm definitely removing the governor. I'm pretty much a noob at this point. At first, I didn't know how to get more than 4500rpm out of a TAV2, but now I'm confident I'll push 5800rpm. I've been doing a little more research and this is what I plan on at this point:
    --------What I need to Buy--------
    +0.100" ARC rod
    GX160 UT2 Flat-top piston
    0.010" OEM Crush gasket---------Should give me 9.7:1 compression and I could always mill the head later
    PVL flywheel with stock key---28* BTDC
    22lb NrRacing Rev kit
    Chrome-Moly Push Rod kits---I can cut them to length
    GX200 long slot push rod guide
    CL1 or CL1 IMP Cam---Because I like that they're hardened
    GX140 Emulsion Tube
    92 and 95 Main jets
    -------What I already have--------
    Homemade header
    Homemade 2" UNI Filter adapter
    Mild Porting
    Yellow TAV2 Contra Spring
    7" driven
    White or blue garter springs as a starting point
    Aluminum Driver wieghts
    I have until Winter to think about this build. For now I'm finishing the rebuild on my snowmobile.
    The machine this engine is on is a 2004 Ty-Rail go-kart. I'll take a picture soon. I think I'll also try a project thread on this.
    Ty
  2. #52
    Senior Member
    Join Date
    Feb 2017
    Location
    Mississippi
    Posts
    278
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    With just an intake, exhaust, jets and a flywheel mine would rev to 7600 give or take. After a rod it will spin to 8000+ on my circle track kart.
  3. #53
    Senior Member
    Join Date
    Feb 2017
    Location
    Mississippi
    Posts
    278
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Also, the TAV doesn't like a lot of rpm 8k + for too long.
    One of my videos on the kart, you'll see at the end the torque converter let go.
  4. #54
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    313
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Got the pictures:
    This is the Ty-Rail. I just took it mudding and didn't get a chance to clean it:
    And my snowmobile. It's a 1980 Ski-Doo Everest L/C Electro 464. This is the current project:
    The snowmobile's engine. It got a bad rod knock last winter. Turns out it fried the Mag side crank pin bearing. You can also see my blown-up yerf dog in the background:
  5. #55
    Senior Member
    Join Date
    Jan 2017
    Location
    San Diego
    Posts
    129
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The MOD2 is hardened, too & would be a much better choice with those other mods. It will give you more power, for a miniscule difference in price.
    Could you use a good pipe at a discount? I have an NR Racing pipe, brand new & unused, that I bought that doesn't fit my mini. I'd sell it for $20 + shipping. PM me if interested.
    Here it is:
    Header, Mini Bike, 3 Stage HP Center Outlet, for Clamp on Muffler, GX200, GX160, 6.5 Chinese OHV, & 212 Predator
    Quote Originally Posted by thedullcarbide View Post
    i'm definitely removing the governor. I'm pretty much a noob at this point. At first, i didn't know how to get more than 4500rpm out of a tav2, but now i'm confident i'll push 5800rpm. I've been doing a little more research and this is what i plan on at this point:
    --------what i need to buy--------
    +0.100" arc rod
    gx160 ut2 flat-top piston
    0.010" oem crush gasket---------should give me 9.7:1 compression and i could always mill the head later
    pvl flywheel with stock key---28* btdc
    22lb nrracing rev kit
    chrome-moly push rod kits---i can cut them to length
    gx200 long slot push rod guide
    cl1 or cl1 imp cam---because i like that they're hardened
    gx140 emulsion tube
    92 and 95 main jets
    -------what i already have--------
    homemade header
    homemade 2" uni filter adapter
    mild porting
    yellow tav2 contra spring
    7" driven
    white or blue garter springs as a starting point
    aluminum driver wieghts
    i have until winter to think about this build. For now i'm finishing the rebuild on my snowmobile.
    The machine this engine is on is a 2004 ty-rail go-kart. I'll take a picture soon. I think i'll also try a project thread on this.
    Ty
Posting Permissions
  • You may not post replies
  • You may not edit your posts
