User Tag List
Thanks Thanks:  4
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Senior Member TheDullCarbide's Avatar
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    398
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Baja_brandon96 View Post
    "power fister" is what Ave calls them.....
    First of all...AvE is awesome!!! Skookum as Frig!!!
    As for the engines, IMO don't worry about 196cc vs 208cc vs 212cc. For that extra few cc's, it doesn't make alot of difference in seat-of-the-pants HP. What does make a difference is the other quirks about each engine. For example, the Hemi Predator has shaft-mounted rockers, but the head can't take very high lift cams without work. The Champions have shaft-mounted rockers and can take big cams, but they're not Hemi's, so on, so forth.
  2. #12
    Senior Member EVOL Tweety Bird's Avatar
    Join Date
    Sep 2017
    Location
    Lakeland Florida
    Posts
    225
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Or you could do like my buddy who lives in Canada does. He will either cross the border to pick up stuff, or depending on what it is, has items shipped to a friend who lives on the US side and then just goes there and picks the stuff up.
  3. #13
    Senior Member trinik7597's Avatar
    Join Date
    May 2013
    Location
    pine plains n.y.
    Posts
    5,805
    Mentioned
    14 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If those are the choices I would say go 208cc clone .. predator bore 70mm Honda stroke . Takes all Honda parts accept piston .. crank , rod , cam etc.. even though in the pics I found it appears to be a predator style valve cover .. in which case if it is labeled 3800 rpm vs. 3600 It should have split.locks and keepers as well as 27/25 valves stock
  4. #14
    Join Date
    May 2013
    Location
    pine plains n.y.
    Posts
    5,805
    Mentioned
    14 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Would be nice to know if it has a hemi flat top in it or a standard dished piston but they don't spec that info
  5. #15
    Senior Member
    Join Date
    Feb 2017
    Location
    Mississippi
    Posts
    278
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by trinik7597 View Post
    If it had a flat top, it would be the ultimate clone engine, no doubt about it... So I'll assume dish piston.
  6. Thanks TheDullCarbide thanked for this post
  7. #16
    Junior Member Butts's Avatar
    Join Date
    Sep 2007
    Location
    Ontario, Canada
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Ok. Thanks for the help everyone. TSC has 196cc clone on sale currently. Think I'll pick that up due to the amount of available parts. Updates will be posted shortly.
  8. #17
    Senior Member
    Join Date
    Feb 2017
    Location
    Mississippi
    Posts
    278
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Butts View Post
    It better have a maple leaf on the side of it.
  9. #18
    Senior Member
    Join Date
    May 2010
    Location
    bc
    Posts
    267
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    At Canadian tire... They sell the Rato brand 212 clone, which is the unbranded parent of the Predator line engines sold at HF.
    As I understand it is a non-hemi pred motor, so the appropriate parts will fit.
  10. #19
    Junior Member
    Join Date
    Nov 2017
    Location
    Ontario, Canuckistan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Butts, I have the 208cc from PA... so far great motor.
    I think the only difference between the 196 and 208 is the bore and the valves (haven't verified yet) so pretty much all clone parts fit. I read on the PA reviews for the motor someone said that this engine uses a non standard wrist-pin. So when i decide to upgrade the rod, I'll have to get another piston + pin. Other than that all parts should be plug and play.
    I already got an intake, E-tube, and jets from OMB... all fits
    If you install an intake you won't need a longer carb stud like the predators. They're already long enough on the 208.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
