User Tag List
Thanks Thanks:  14
Likes Likes:  0
Dislikes Dislikes:  0
Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: Hemi head
  1. #41
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,680
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    No compression height is distance from top of wrist pin hole to top of piston. Hemi piston is .020 shorter than non hemi piston.
    Ole
  2. #42
    JBeasty's Avatar
    Join Date
    Jan 2014
    Location
    Bay Area, CA
    Posts
    185
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Great I wonder if I increased my compression at all...
  3. #43
    JBeasty's Avatar
    Join Date
    Jan 2014
    Location
    Bay Area, CA
    Posts
    185
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    After thinking about it (I need to think more, post less...), I realized the +0.020 rod makes me even, and with the stock dished piston, the recessed portion is 0.050 lower than the flat top. So I did gain some compression.
  4. #44
    Senior Member DeadPixel's Avatar
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    520
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Part # 212FTPISTON570 from NR Racing will put your piston back up it's about $17 and is a flat top. It comes with the rings. Make sure you run the correct rings with the piston you use. There is I believe 3 different ring sets for the predator.
  5. #45
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    520
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If you do swap the piston the top and second ring are the same on the predator. 550 and dished piston but the oil ring is different. The predator .570 flat top uses different rings on all 3.
  6. Thanks JBeasty thanked for this post
  7. #46
    JBeasty's Avatar
    Join Date
    Jan 2014
    Location
    Bay Area, CA
    Posts
    185
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks, good to know. Fortunately, my piston came with all the rings. I'm gonna leave it as is for now and see how it runs. It's all buttoned up and ready to start. All I need to do is get some oil in it, rig up a temporary gas tank, and cross my fingers
  8. #47
    JBeasty's Avatar
    Join Date
    Jan 2014
    Location
    Bay Area, CA
    Posts
    185
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Started on 4th pull. A few putts with the choke on, then took choke off and it fired right up. No adjustments to the carb other than a 1/2 turn on the idle adjustment screw. Seams to run really well. Idles fine and revs up quickly. Hi-tech test stand:
  9. #48
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    520
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nice good to see things went well.
  10. #49
    JBeasty's Avatar
    Join Date
    Jan 2014
    Location
    Bay Area, CA
    Posts
    185
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Took it out for a test run today. Good God, I'm glad I didn't shoot for more power. This thing wheelies without trying, and is faster than I'm comfortable going - at least til I get used to riding it. I'm used to the weight and stability of motorcycles. This thing is squirrely!
  11. Thanks TheDullCarbide thanked for this post
  12. #50
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    520
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Lol before I got in to mini bikes my goal was to build a bike that would do 60. My new goal is 40. I have only had mine up to 28 so far. They definitely feel different than motorcycles. The sketches thing for me about these things is only having a back brake. I would feel a lot better at high speed if I knew I could stop in a reasonable distance. A lot funner than any ATV in my opinion though. I could have got a nice dirt bike or quad but have this instead.
  13. Thanks TheDullCarbide thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
