User Tag List
Thanks Thanks:  8
Likes Likes:  0
Dislikes Dislikes:  0
Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
  1. #41
    Senior Member DeadPixel's Avatar
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    520
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    That's a nice looking motor.
  2. #42
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    12,290
    Mentioned
    69 Post(s)
    Tagged
    2 Thread(s)
    Rides
    Thanks DP , I got this in yesterday . Now I just need something to put this engine in .
    Lil Indian, Ruttman, DB30, Warrior, lil Bill, EZ Rider, Savage SSC , Powell, BONANZA
  3. Thanks shadowfocus603 thanked for this post
  4. #43
    Member
    Join Date
    Aug 2017
    Location
    NH
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    What is the weight on the Raceseng flywheel? I am going between that or the 1.75lb flywheel from ARC.
  5. #44
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    12,290
    Mentioned
    69 Post(s)
    Tagged
    2 Thread(s)
    Rides
    @shadowfocus603 weight of this Raceseng flywheel is 3.5 lbs. 30 degrees of timing built in.
  6. Thanks shadowfocus603 thanked for this post
  7. #45
    Senior Member KMC3420's Avatar
    Join Date
    Oct 2015
    Location
    Arkansas
    Posts
    878
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nice build OND, how is the engine running with the fuel pump? I like the orange tins.
  8. #46
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    12,290
    Mentioned
    69 Post(s)
    Tagged
    2 Thread(s)
    Rides
    Thanks KMC3420 , torque converter got in the way of the fuel pump so I tried it with out the pump ….and the engine is scary , but I like it . I've not had it maxed out yet because the old Warrior I put it on doesn't have that good of tires on it...yet .
  9. #47
    Senior Member TheDullCarbide's Avatar
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    737
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Did I miss what cam you put in it?
  10. #48
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    12,290
    Mentioned
    69 Post(s)
    Tagged
    2 Thread(s)
    Rides
    Cam is a Dyno cam 265/265 lift or CM grind .
  11. Thanks TheDullCarbide thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
