User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Senior Member DeadPixel's Avatar
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    510
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    So I was reading his articles... Are you saying you used JB weld successfully in the port? I have thought of using JB Weld but was un sure if it would stay.
  2. #12
    Senior Member TheDullCarbide's Avatar
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    722
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by DeadPixel View Post
    Wondering if it would stay in the exhaust port...
  3. #13
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    722
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    @DeadPixel I just took thin strips of 120 grit (had it laying around) and sort-of flossed it around the short side to finish what I could reach with the burr.. Turned out beautiful.
  4. #14
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    510
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nice, pictures!!!
  5. #15
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    510
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Ya i want to try the JB weld on the exhaust.
  6. #16
    Join Date
    Aug 2017
    Location
    Allentown, PA
    Posts
    722
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nice, pictures!!!
    My usual potato wouldn't be able to see it. Might have to try the bore scope.
  7. #17
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    3,644
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Rides
    JB works great on intake if properly prepped. Do not use on exhaust as it will come loose.
    Ole
  8. #18
    Senior Member EVOL Tweety Bird's Avatar
    Join Date
    Sep 2017
    Location
    Lakeland Florida
    Posts
    538
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yeah I only did the hump on the intake side, been 2 years and still running strong.
  9. #19
    Senior Member FirePowerMinis's Avatar
    Join Date
    Oct 2012
    Location
    Flint, MI
    Posts
    803
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I 2nd or 3rd the JB Weld on the long side behind the valve stem. Same with the emery cloth. I used it on my 2 strokes in the 70s
    With the fine carbides, I keep an old short/stubby candle on the bench and give the burr a little spin to coat it in wax to avoid loading up.
    I like the 1/8 shank oval burr as the radius on the shank end helps to reach farther around the short side.
    The flat floor is what I try to emulate on heads that aren't so that's a head start, IMO. I do widen the sides a bit more than the pics shown.
    I think the intake bowl is already bordering on too large, above the 85-88% of valve head diameter. Makes big valves a practical mod.
  10. Thanks TheDullCarbide thanked for this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
