User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Senior Member EVOL Tweety Bird's Avatar
    Join Date
    Sep 2017
    Location
    Lakeland Florida
    Posts
    626
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Got this idea, any thoughts?
    So on my day off I'm of course tinkering with the bikes. Both have modded Predators, one Hemi, one non.
    Flywheels/rods/cams/emulsion tubes/jets/ported and polished/22 pound springs/governor and low oil deletes, high flow air filters.
    Okay as to the latter As most know you have an adapter that bolts to the front of the carb so the air filter coupler can attach to it. Now looking at it I'm thinking that the adapter design can be detrimental to air flow, as you have the small hole in the center for the air to travel through, but you also have a flat approx. 3/8" around the hole. So any air traveling down from the filter hits the flat and can disrupt the air getting into the carb. Yeah I know, way over thinking it.
    But hear me out, old school racing time, when you wanted a straight shot of air getting to your carb you installed velocity stacks to direct the air straight to the carb.
    Now finding a tiny diameter velocity stack is a bit of a problem. So here's what I'm thinking and what I built. A velocity stack to fit the coupler on the air filter adapter, but with a tweek. I made up a venturi to direct all the air from the stack into the hole on the adapter. At low speeds the engine doesn't need a lot of flow so the setup does really nothing. But at higher speeds instead of a bunch of tumbled air going to the carb, you would get a higher speed of more clean air going to the carb. Higher speed, lower pressure to help pull more fuel/air to the head.
    And just to be nuttier than a jay bird, the velocity stack is a left over header collector connector, 3" long and 2 1/2" in diameter, with a trumpet end on it. The venturi is nothing more the the top of a Sea Foam can stuffed in the stack upside down. It's small opening is nearly a dead nuts match to the one on the adapter. For a filter I cut a piece of heavy screen that lays inside the stack on top of the venturi, with a piece of the foam filter from the non Hemi engine on top of that.
    Engine fires up just like normal, but I swear I hear more of a cackle sound now from the stack, I guess the harmonics from when the intake valve slams shut. Engine seems to respond normally if not a little bit more snappier to the throttle. With the hurricane that just pushed by I haven't had a chance to see how it runs on the street, but I plan on testing with the old set up and then with the new to see if it actually did make a difference.
    I'd show you photos but the site still won't let me post them, so you'll have to use your imagination.
  2. #2
    Senior Member DeadPixel's Avatar
    Join Date
    Feb 2017
    Location
    Moses lake
    Posts
    538
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have thought about this too cuz the intake almost has no length to it for tuning. Its easy to put a long header on the bike and get a little bit of an effect for tuning but the intake is nothing. You really want the length between the carb and head but though that doing like you did might still have some ram effect besides smoothing out the air like your trying to do. I have thought lightly modding a mikuni intake with the stock carb set up to see if it has any effect on power. You got the wheels turning again so now I might have to start this project.
    I think the best way to see if you gained some power is to do a power run up a mild grade with and with out the intake and see what gives you the best average top speed up the hill.
  3. #3
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    9,214
    Mentioned
    29 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I made a couple using stainless steel shot glasses I found on Ebay, hard soldered to flanges I made. They bolt on to Tecumseh, Tilly, etc anything with that bolt pattern on the air filter housing adapter. The concept is still valid all over this town, especially on top of Hillborn and the other mechanical injections systems on street rods. Also still used in vintage karting classes, where allowed. I have one on a warmed up WB as well.
    Solid technology.
  4. #4
    Join Date
    Sep 2017
    Location
    Lakeland Florida
    Posts
    626
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hmm,never thought of the shot glass idea Dave, oh well, I kinda like the look the bigger stack has. Still raining out so no rides today before work.
    Back to the idea, does having more then one venturi actually add a bit of boost per se. No not like a turbo/supercharger, but then again maybe it does? Now instead of the tumbling air being delivered to the carb venturi, the stack with it's venturi is delivering a faster increase of clean or smooth air. Like DP said sort of a ram effect on the carb. Similar? as the ram systems don't do anything for putting around, but they can make a difference in hard all out power.
    If this contraption actually works I guess I'll have to look into jetting as I'm sure the change will affect the mixture when it's used.
    Better go buy some more sacrificial spark plugs for reading the results.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
