User Tag List
Thanks Thanks:  10
Likes Likes:  0
Dislikes Dislikes:  0
View Poll Results: which camshaft for the Predator
Voters
8. You may not vote on this poll
  • CL-1 dyno cam
    3 37.50%
  • BSP-3 racing cam
    3 37.50%
  • Stock cam w/out governor
    2 25.00%
Page 8 of 8 FirstFirst 12345678
Results 71 to 72 of 72
  1. #71
    Senior Member
    Join Date
    Jan 2017
    Location
    San Diego
    Posts
    156
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yeah, I thought it had a lot of nuggets of wisdom, in helping to understand why one cam performs differently from another. Makes selecting an appropriate cam for your needs a lot easier.
  2. Thanks TheDullCarbide thanked for this post
  3. #72
    Senior Member
    Join Date
    Jan 2017
    Location
    San Diego
    Posts
    156
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Daniel Coop View Post
    I won't even pretend to act like I understand cam technology enough to tell you how a cam with less lift and duration seems to pull the same as one with more of both, but it does. It seems to be a smoother more consistent powerband across the entire RPM range. They are quite similar in performance somehow and have the same max target RPM and both recommend the use of larger carbs. I couldn't honestly tell you that one was better than the other.
    Russell at NR's info sort of answers why the CL-220 would have a wider powerband, since it has a 105 ICL on the intake & 111 on the exhaust, while the CM has a 108 ICL on both. It is set up to have a wider range, regardless of the lift & duration differences.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
