Ready to order sprockets for the jimmy gote. 13 hp, with jackshaft and torque converter. Be used for trail riding mostly, not really interested in high speed. If it does 35mph I'll be happy. Needs to be able to carry myself and a couple hundred pounds of elk. I was think of a starting gearing around 7 to 1. That sound reasonable or am too low? What value do I give the TC when figuring ratios? Using number 40 chain. It is my understanding that 40/41/420 sprockets all will use 40 chain, am I correct in that? I see several bolt patterns on wheel sprockets. I am running a 22 11 10" rear tire. are some bolt patterns more common and easier to find then others? My rear axle is a 1" keyed shaft so am looking at go cart hubs. My thinking is the larger 4" pattern should be stronger but didn't want to dedicate myself to some odd sprocket that will be a pain to replace later.
