Minibike find at Flea Market
This past Sunday I found a minibike it is a Blitz frame with a Honda GX110 3.5 HP but missing a few things.
I just noticed I forgot to take a pic of the chain side. I measured it so I think it takes a 3/4" centrifugal clutch.
I am looking for help from the members on what parts to order for it.
thanks
1. Throttle and cable
2. clutch and chain
3. chain guard
4. left side foot peg
There is an aftermarket hydraulic disc brake that bolts right on for around $30-40. It uses the same disc and is exponentially better than the manual squeeze that's on your bike. Some one will post the link for you,
Shame the stock twist throttle is gone. I really like them for the integrated kill switch. Here's a link to a set that works well...
https://www.amazon.com/Throttle-Accelerator-Gripsand-Doodlebug-6-5HP196cc/dp/B073LQNRRY
Clutch
https://www.amazon.com/Clutch-Chain...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Chain
https://www.amazon.com/PGN-Roller-C...r_1_5?keywords=35+chain&qid=1582049741&sr=8-5
Chain guard is no longer available through Baja. You would have to use a generic clutch cover. Same with the footpeg. There are some Facebook groups you can source used parts as well as the classifieds here. Also, the stock engine for that bike is not the same mounting pattern as the Honda GX. Did they re-drill the engine plate in the bike? If so, be sure the chain lines up correctly. If not I suggest using the engine plate adapter. MAkes life easy!
I've had many Doodlebugs, which this is the same as this, and have never seen a kill switch integrated into the throttle. They just use a generic handlebar mounted one that can be bought from many places for $10.
DaddyJohn
Chain and clutch for $22: here
Throttle, cable, and grips for $12: here
Footpeg is $10: here
Might be a better deal on a peg somewhere, but the other prices are about as cheap as I've seen within a buck or two.
I always thought they were part of the twist. Thats good to know!
