For Honda and Honda Clone gx160 (5.5 hp) and gx200 (6.5 hp) Engines
This is the size list so far of the bolts and some torque values. Please let me know if you have anything to add. Please note these are the stock sizes and torque specs, please when installing aftermarket parts consult the Manufacture for proper bolt size and torque specs.
Bolt /size /(torque foot/lbs)
Connecting rod bolt M7 x 1.0 (9 ft/lbs)
Cylinder head bolt M8 x 1.25 (17 ft/lbs)
Flywheel nut (special nut) M14 x 1.5 (54 ft/lbs)
Rocker arm pivot lock nut (special nut) M6 x 0.5 (7 ft/lbs)
Rocker arm pivot bolt M8 x 1.25 (17 ft/lbs)
Crankcase cover bolt M8 x 1.25 (17 ft/lbs)
Muffler mounting nuts M8 x 1.25 (17 ft/lbs)
Cylinder head intake bolts. M6 x 20 1.00 (17 ft/lbs)
Cylinder head exhaust bolts. M8 x 25 1.25 (17 ft/lbs)
Crank Shaft bolt. 5/16"-24 x 3/4" fine thread (30 ft/lbs)
Crank case mounting bolts 5/16"-24 x 3/4" (17 ft/lbs) (some engines use M8 x 20 1.25 pitch) (17 ft/lbs)
If you only have a Inch Pound torque wrench multiply the number of ft/lbs by 12 (FT/LBS X 12 = Inch/LBS)
