Do you have a photo ?
Size tubing ?
Measurements and or bends ?
I ask because I started to make sissy bars about a year ago out of Steel OR Polished Stainless steel.
Even if someone could supply detailed pics and measurements I could make it. ?
One of my handmade sissy bars >
Found this on the net;
The sissybar is made from 5/8" tubing, about 1/16" wall tubing.
From the top of top "U" bend to center of lower bends it's 16" measured from the back of sissybar.
On the bottomside of the lower bend, the lower tube length is 9" from center of bend to end of tube.
Sissybar is 5" wide just below "U" bend, 6-3/4" at lower bends, and 6-1/8" at end of tubing.
The angle of the sissybar is 60 degrees on a protractor.
Mounting holes are one drill size over ¼", and spaced at ½" and 6-7/8" from the end of tubing.
