6.5
  1. FastMiniBike
    Intek 206 Question
    Hello all, I have a Briggs Intek 206 and I wanted to add a billet flywheel and con rod to it so I can safely remove the governor. Problem is, its box stock and I don't know what rod and flywheel to get. If anyone knows what length to get Id be stoked. Thanks!
  2. E
    Never underestimate a 6.5 Predator
    By the power of Harbor Freight...... https://www.youtube.com/watch?v=WSc9CVyje5Y
  3. novadose74
    Tecumseh 6.5 hp powersport ignition question
    Does anyone have a part number and/or know where I can find an ignition coil for a Tecumseh 6.5 hp Powersport engine? Thanks. I'm going through withdrawal not being able to ride my mini!! Tom
  4. J
    Baja Blitz w/ 6.5 and Stage 1 Kit - What's next.
    Well I finally got the bike done(so far) with the 6.5 hemi predator, HRMB engine plate/hardware/clutch/chain kit, and OldMiniBikes Stage 1 Kit. Gets up goes quickly, can launch on my Kawasaki KD100M and get a healthy head start before it gets passed on the top end. This thing is a blast. Throttle...
  5. cudaman
    Looking for correct HF 6.5 Greyhound gaskets
    I ordered a set of gaskets for a greyhound HF 6.5 (about 7 year old blue clone greyhound) and found they didn't fit both the side crankcase (see pic) and valve cover (mine has 5 bolts (set for 200cc Honda clone has 4 bolts). The set I ordered was listed as a gasket set for the 196-212 cc engine...
  6. danford1
    Manco Thunderbird, 6.5 hp Predator, many new parts, $450
    Manco Thunderbird with 6.5hp Predator engine. New clutch, new clutch brake, new chain, new seat bottom and recent tires. Ready to go, needs nothing. Fast. $450 call or text 248-895-1444 Danford1
  7. DirtBug30
    Greyhound 6.5 hp (predator identical) Engine Problems. PLEASE HELP ASAP!
    Hey everyone! New user here. So awhile back i rigged my engine up with a 6.5 hp greyhound engine which is almost exactly identical to the 212cc predator engine. The other day i had it parked outside and i think the wind pushed it over so it was sitting on its side overnight. I think possibly...
  8. K
    Replaced Baja MB165 engine with a lifan 6.5 electric start.... Need Performance parts
    And I found out its a really tight fit. I had to take the muffler protector off, and air filter cover off. The gas tank cap/knob is centered, so you can't use it with the tank on. I will take the one off the original baja motor and use that if it fits the lifan. The metal tanks hang a lot...
  9. M
    What performance part do i have to get for my Hensim 6.5 hp 196cc
    What performance part do i have to get for my Hensim 6.5 hp 196cc it have to be honda clone parts ? or predator 212 parts would fit too? :thumbsup:
  10. Studeman68
    6.5 HP engine for only $1044
    And 50 sold? :out: NEW 6.5 hp engine go cart tiller log splitter 6.5hp gas motor mini bike recoil
  11. Biffmini
    6.5 ohv parts
    I picked up these parts from ex kart guy. I can't remember what he said 6.5 Briggs or Clone, I know nothing about these parts. He did say carb had work on it & it was illegal For race... And ran great with it. These parts need a home, I'm hoping someone can use them. I can send more pics...
  12. danford1
    Great price on 6.5 hp Predator
    Great price. Danford1
  13. Rapidrob
    Need 6.5 HP Greyhound engine muffler ideas
    I have a 3/4" pipe thread sausage type muffler on a header attached to a Greyhound 6.5 HP engine via a 24" header. The original muffler cannot be used due to the placement of the engine and air intake. The original muffler was very quiet. I need a quiet muffler,even if I have to weld it on the...
  14. Cap'n kanuckles
    Baja 6.5 hp Minibike JACKSHAFT assembly
    Works good $35 shipped
  15. BBQJOE
    Holley 4 bbl carb on 6.5 clone.
    But, would it work? :biggrin:
  16. M
    honda clone 6.5 crank
    My Baja MB200 Mini bike is a nightmare. I've had it for 3-4 months, and I've broken the brake drum, both chain tensioners, handlebars, chain, headlight, footpegs, kickstand spring, and now the crankshaft(?), twice. The crank/drive shaft snapped off while riding, so I drilled and tapped it and...
  17. G
    Predator 6.5 No start
    Hey guys, just wreaked my mini bike about a week ago. When I wreaked it I noticed that my chain was extremely loose, so I figured thats why it wasn't starting, well the next couple of days later I tightened the chain, but still no start! We checked the spark plug and it was getting a spark so...
  18. steven Durham
    Briggs & Stratton 6.5 HP Intec engine
    OK now is the time to sell this never used motor, it was bought for a Go Kart originally but I tried to set it up for use in a mini bike and as we know life changes and we have to adapt. I pulled off the linkage and the tank to fit the engine into a frame and I was going to use a slide carb...
  19. B
    6.5 clone coil gap
    I searched and didn't find a definitive answer; what is the suggested coil gap for a STOCK 6.5 clone? (Particularly the 197cc on a Baja Warrior, if it matters) I already checked the user manual as well, no luck.
  20. FloridaMiniBikes
    OHH Tec 5.5, 6.0, 6.5 difference?
    How in tarnation did That injun guy get different HP ratings from the same bore and stroke.:confused: I looked around the net and still am dumbfounded. Please enlighten me oh great ones?:anon.sml: Old ancient Mini-Bike proverb says..... Curiosity killed the cat, but satisfaction, brought...
