Hi guys, I've been gone from the forums for almost two years, due to health issues and losing my internet and electricity due to medical bills, but I'm doing a bit better now, got everything turned back on and started working on my Baja MB200 again.
So, here's where my question comes in. I...
Hi Guys - I just got my paper filter kit (along with a header - lots of popping on deccel so I guess its running rich, filter may help lean it out) for my sons Predator 212 which has been a surprisingly strong engine and held up well! Question is this, being a user of K&N filters in 3 of my cars...
I'm trying to put a drum sprocket brake on my mini bike but I have a couple questions. If my sprocket is 5 inches across should I go with a 5 or 4 1/2 drum brake? or Smaller?
Also, I'm interested in putting an air intake on my Tecumseh H35. I know there are very few after market parts made...
Hello,
I have an original style doodlebug with a 6.5 predator and I'm looking into an air filter, but it seems most recommend this along with a new carb.
Am i okay to just upgrade air filter and and rejetting the stock carb? Or is that not enough?
Thanks
Hi, have a 212cc Predator on my Trisport TS-110
Riding it today i tipped it and the cover for the air filter broke off
i cannot find a stock one and wish i could, i seen an 'aftermarket' one on ebay but am cautious about buying it.
anyone have an aftermarket one and could comment on it...
I just picked up a minibike with this engine and it has no air filter of any kind on it, no brackets or anything. I scoured the internet looking for the proper air filter assembly to no avail. Any thoughts on where I can get one? I really don't want to run this engine with out an air filter.
How do you size the carburetor when buying a custom air filter for any engine? I've heard people talking about 20mm carbs and stuff like that, but I'm a bit of a newbie and i don't know how to do that..suggestions??
Is it in the manual of the engine??
Wanted to use a new B&S engine on an ARCO so that I could keep the gas tank on the engine. Picked up a B&S 525 series because height was good to fit in frame. Screwed up and didn't consider how the carb was mounted on the engine. It has an intake that sets the carb down low right into my rear...
Hello,
Well, I finally found a really nice 5hp Funpower motor for my minibike project.
When I got it home I discovered that there is not enough space to fit the engine with the stock air filter and muffler setup!
Are there any aftermarket (no need for Hi-performance.. just shooting to...
I decided to make this a post on its own.
Hard starting... when you change the air filter and or exhaust, the idle circuit does not create enough vacuum... the solution is to open the idle jet. Where is the idle jet? you ask?
its under the throttle set screw...
1 - Take out the throttle...
i was riding my doodlebug today and when i reach full speed it starts to cut out and sounds like the engine is going to stall so i put new gas in it thinking it was bad gas and it did it again, my bike is only a couple days old, i got it for christmas so i was wondering if maybe the air filter...
