I got a "Barn Find" Rupp today. It was in a heated pole barn for the last 30 years according to the person I bought it from. He claims it came from the dealer like it is. I have the paperwork from when it was sold showing chassis number and engine number. The numbers on the frame and engine...
Will this 2 speed jackshaft #713845 UNIVERSAL COMET 2 SPEED CLUTCH KIT work with this clutch Max-Torque Dual Sprocket Clutch for Two Speed MiniBikes ? I'm hoping to pair these 2 together on my 1969 Rupp Sprint. It looks like the 2 speed sprockets are further apart than the sprockets on the...
I can't stand it anymore. I just can't stand to ask to use other people's machines all of the time. I bought this thing and I hope it turns out OK. I don't have everyday use for a lathe but this will take care of the things I need to do. It threads funny but like any machine I will get used to...
I'm looking for a cheap combo for a air filter kit for my 212 hemi . I have looked all over online and want to find the cheapest one including shipping any suggestions would be great
I'm currently looking for a pair of 4.10 - 3.50 - 5 wheels and tires. I would like wheels with tires and a sprocket but just wheels may work as long as they're ready to accept a sprocket. Paint condition isn't a big deal because I might end up painting them.
Thank you
Hopper055
Looking for some fun goodlies for a HF blue clone.
Guess they all interchange??
Cam, springs, billet rod??
Or just a good combo of parts laying around to wake one of these up a little.
PM please and thanks in advance.
What is the best gear combination for quick 125 foot spurts.
Engine Crank:
Half Jack (from engine):
Half Jack (other side to rear wheel):
Rear Wheel:
Engine: Harbor Freight (clone) 5 hp stock
Rider: 225 lbs
Wheel: 12" with slick from the front wheel of a "John Deer" O-Turn Mower.
I'm...
I picked up this little 3.5hp Tec today at the scrapyard. It has a clutch on it like I've never seen before. Both belt and chain drive. I removed it from the motor, only to find out that it is made specific to this engine/shaft. The shaft is stepped down twice.
Not really sure what this motor...
Spinner 8 inch wheel with rib style tread 4:80 / 4:00 X 8 The spinner is like Bonanza used on some mini bikes.
Asking $35.00 Firm plus shipping from Zip 97229
Steve :scooter:
NEW AZUSA " TEN INCHER " Steel wheel with new INOUE 3:50 X 10
universal tire and tube. Has new 5/8 inch bearings.
Asking $ 55.00 plus shipping from Zip 97229
Steve :scooter:
SPECIAL during the month of April 2011:
GX200 cam and high rpm recall tachometer $175 shipped to the 48 states.
Your choice of any of my profiles on the cam.
Tim Isky
http://www.oldminibikes.com/forum/photopost/data/500/thumbs/GX200_CAST_CAM.jpg...
I have 3 of these cam/pipe combos available:
The cam comes with your choice of .270, .276, .290, .310, .350 or .370 cam lift
and has 246° duration @ .050".
The pipe is 3 stage: 1" i.d. then 1 1/8" i.d. then 1 1/4" i.d. and fits the Joes frames and is supposed to fit the doodlebugs as well...
Hey all,
Neat headlight & tail light combo that will work with internally charged motors or 12v battery external bikes & go-carts. Headlight is off a Baja Heat and re-configured for common auto bulbs. Tail light is mounted on a bracket and uses an economy trailer lens/bulb.
$20 shipped...
I am going to race my mini on a 1/4 mile flat clay track (oval), what clutch , and rear sprocket combos should i run ? I want to be able to gain my speed in the straights.
3"x5" split steel wheel, 4-bolt hub and Dunlop 10x4.50-5 CIK/Enduro kart racing slick. The tire is used, but has plenty of tread as indicated by the casting nipples and wear indicator holes. -- $20
