OK guys I have a question for you guys running stock or SA carbs on a Honda or predator with the gov removed and a stock tank ... Can you please share pics of your throttle hook ups ..
I have a Loncin 125cc clone engine. It is a horizontal four-stroke with gearbox. I'm needing to fab or otherwise obtain an exhaust system for my conventional, old school minibike. The exhaust manifold studs are 45mm center-to-center. The port is 33mm in diameter. For whatever its worth...
I have a few questions regarding connecting throttle cable.
There appears to be two locations where cable can be connected.
One is at the side of motor and moves up/down vertically.
Or it looks like it can be connected on the bottom part horizontally
Which location should be used...
This is an add for a Manco Trailcat from 1979/80, first off I bet some of you are surprised its that new :wink: But take a good look at it and note the decal on the number plate says Fox and the chianguard is the Fox used chainguard that started life on the the 10" wheel single speed bikes, got...
Im a throttle connection away from getting this thing road ready . Just wondering what your throttle connection looks like . It appears like I will need to make this pull from the bottom . I have several contraption to make this work properly just checking out others setups that might work...
New Years eve I ordered up a collection of parts for my predator 212. Yesterday I installed the parts. Well now I'm missing an arm or two and the linkage springs.
What I'm looking for is an idea or two on how you hook up the throttle after removing a bunch of parts. Maybe a picture...
Ok, I don't think I'm doing too bad for a newbie.
Got throttle cable where it needs to be. Idling perfect just need an idea or thoughts on hooking the cable to the arm. Up to this point I have used scrap stuff. Bolts with washer falling off, cause of idle..
Pictures, descriptions of...
Well for the past 2 years I had a guy sandblasting all my frames and parts. I hadnt talked to him for a while since I have been semi retired. But I have been holding onto one last project and decided to drop it off while I was in the area. He wasnt home so I left him a note with instructions...
I picked up a new Predator 212 engine and the air cleaner appears to be different from what is shown in the parts diagram.
Specifically, the one in the parts diagram is two pieces. Remove the top of the air cleaner along with a bolt or screw and the top of the air cleaner comes off for...
Hi Guys;
Tried to do some searching on here regarding this but could not find anything.
My VT 10 Super Bronc project is coming along. I have one of the original super bronc gas tanks (that sits on top of the frame) that I would like to connect to the 10 hp tecumseh gas tank. Has anyone...
After taking apart my 6.5 clone today I noticed the connecting rod has no bearings in it? When I ordered my billet rod it says it comes with bearing inserts. Does the aftermarket rod have the rod cap machined out to accommodate bearings? I would assume the bearings are sized to work with the...
I have a tecumseh HS40 engine and I'm trying to figure out how to connect the throttle cable to the lever with the small hole in it. I have searched and searched for a picture but I always come up empty. I was looking at a cable stop but I'm not sure how it would connect to the lever. Your...
I'm an old geezer from Utah, the home of the Tote Gote. So we are trying to restore some of the old tote gotes. Many of you young kids may have never seen a tote gote. They weren't much for speed but they could climb anything. I love reading the forum to see whats going on and will bust in...
