diy
  1. ole4
    DIY led lighting.
    I was asked in a headlight thread to do a DIY on LED lighting so I will pass on what I have done to add led lighting to my minibikes. I will cover the following, Advantages, Converting a period correct sealed beam to LED bulb, Led lighting for headlamps with replaceable bulbs, different types...
  2. TDB
    DIY predator 212 clutch cover/clutch guard
    I went out for a nice ride after I finished swapping a Predator 212 onto my mini bike and ended up shredding my shoe on the exposed clutch.. no bueno. I looked a little bit online for a clutch cover but I didn't see anything that I really liked the look or the price of, so I thought what the...
  3. C
    Mikuni manifold DIY facing rear
    I need to change direction of carburetor for fit. Has anyone used this method to redirect carburetor towards rear? Any performance issues using small section of hoe? Using radiator hose in-between cut manifold AGK - DIY Curved Manifold - Affordable Go Karts thanks
  4. BBQJOE
    DIY Cable ends that work!
    I tried just about everything there is on the hot side of things. Of course lead won't stick, and it's too soft anyways. I tried a quick zap with a wire feed welder, and the cable just went up in smoke. I tried the one off of youtube where the guy melts silver solder into a hole drilled in wood...
  5. Eliminator
    Wanted: Home made DIY mini from the 1960s made from bicycles...
    Looking for a do it yourself, homemade DIY mini made from the plans popular mechanics and boys life used to offer around 1965 66 using old bicycle frames. A lot of the plans called them Scoot'r-bike. The more unique and features the better. Made a few as a kid. Rather find one from the era...
  6. WrenchDad
    DIY paver brick sidewalk project.
    Well after some advice on the best way to cut paver brick a month and $61 dollars later I have it done. this was my first time doing this and I was on my own. I started it Sunday afternoon and finish Monday afternoon (about 10hr's total). My plan was to re-do the old limestone sidewalk with...
  7. cpu77
    DIY Honda clone 6.5HP/Predator Hemi DIY billet rod Video
    I am building my Predator Hemi 212 engine and would like a good video giving details on installing a stock length billet rod. I am also installing cam and springs. I found great videos for that. Flywheel is easy done that before. Any suggestions?
  8. pomfish
    Inexpensive DIY Alarm for barn needed
    What I need is a simple Bright Lights/Loud Alarm and maybe 3-4 magnetic door sensors. What I do not want is cameras,cell phone hookups, etc. I know which side of the structure is vulnerable, we are light sleepers, and if it is bright and loud enough they will get out fast. When I check...
  9. WrenchDad
    DIY cement paver advice
    Hi guys, I have a sidewalk project I'm doing and I know there are alot of DIY guy's on this site. Or maybe even some one who does this type of thing by trade. So I need some guidence. I already have available a couple hundred 6" x 9" x2 1/2" keyhole pavers. but I dont have any edges and I cant...
  10. wastelander bike
    wastelander bike
    Custom ride built with any part I could find layin around cuz I'm a poor, cheap bastard and figure why pay for sumthin u can craft urself. Except for the engine, I spared no expense and plan on continuing performance even further.
  11. sum fairly descent webs
  12. wastelander bike
    wastelander bike
  13. TANKSAREUS
    DIY Pipe Bender
    Eventually decided I had no choice on this one - the local bender for sale is almost 1000$ and its a wrap around type, not the high quality pull around type. The JD2, JMR and Hossfeld prices are not bad, but shipping is insain. This type of bender is essential for me as everthing has to be...
  14. TANKSAREUS
    Homemade - DIY - Header
    Put this together for a friend this weekend and thought why waste good photo's. Coz I know you guys love the Pics. So best thing to do is have the motor in the frame. Remove the stock exhaust in the case of clones. The gasket will be used to make the flange for the header. Place the gasket...
