I've read a few post and searched threads and need to install a pulse line for my fuel pump. Wondering where y'all would drill and tap? Tecumseh uses vacume fuel pump I believe, I also have no experience in this and am learning as I go. Whoo hoo!
The tube coming out of the cover below the...
There's a listing on craigslist listing for a 5hp briggs and stratton and it looks decent the guy said $60 and its mine it starts on starter fluid he said but then dies so its probably a carb issue. Is this a good price and will it be a cheap fix?
So i’ve thrown together a pretty strange setup for my chain tensioner on my minibike. The issue i’m running into however is that the chain is completely destroying the roller wheel. I’ve had on wheel get completely eaten all the way to the bearing and now caused a chain to break. My question is...
Hello! I have found many digital tachometers to fit my minibike, one wire going to ground, the other to the ignition wire, but I would like to figure out how to add an analog one so it looks a bit nicer. Anyone have any insight? Im a bit of a noob but its going on a baja doodlebug with a...
Hey all! Ive got a monster moto 80cc and whenever I pull start it, the engine won’t stay running. I’ve cleaned out the carburetor and I cleaned out the air filter, replaced gas, and replaced oil, yet I still see the same results. I can’t attach a video of the issue. Any help is appreciated!
Hey all, I don’t know if this forum is still active but I have a monster moto 80cc minibike and it has been in storage in the garage over the winter and now, after I drained and replaced the gas and oil it only starts for a couple seconds then the engine stops. When I turn the throttle within...
So after about 2 years of not starting, my preadator 212 ran into another issue, the kill switch doesn’t work, not even the stock on on the engine. My question here is how do i fix this, i am not good with wiring nor do i know how to identify the issue. Any held would be great!
About 2 years ago I bought a mini bike to mess around with and had zero knowledge about them going in. I bought a "Ruttman mini-bike" on the higher priced side as I wanted something in better condition and wouldn't require much maintenance. I've recently have been wanting to give it an upgrade...
Hello, I just picked up a Tote Gote from a guy because I am a glutton for punishment. I am not 100% sure that it is a 600 series but the research that I have done points in that direction. It has the H60-75083B (I cant find the 75083B on the Tecumseh site) From what I can find it is a 6hp...
HI guys i'm going to look at a mini bike tomorrow , but didn't know if it was vintage or not . I try to post pictures but it didn't work , anyways it's has a scrub brake and the brake lever is in front of the right foot peg instead of behind it. One piece fork with a large fork plate and the...
I have a question about my proposed gearing for my minibike
After my calculations I concluded that if my engine was spinning in the middle of it's power band at 3600rpm, I would be topping out at 37MPH. Now I'm not sure about you but I want to get at least 45mph from an 8HP engine. I have...
Hi all, after some help i bought this bike couple of years back and i would like ot know what it is so i can restore it back to original spec. i have seen another one the same in the what is it section however no one had commented saying what it was.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
New Help Locating a replacement Steel plate sprocket for my 1969 mini bike.. I already ordered the wrong one and having trouble finding the right one.
Its a three hole set up.. 2 1/2in apart and 1 inch from the center mount!
i have pictures if needed!
