hub
  1. K
    Rear hub for Manco Thunderbird
    Hello all, Great site! I have an old Manco Thunderbird that I need a rear hub for (dual flange, 7" overall length, 5/8 bearing ID). Thanks in advance for any help! Ken
  2. B
    Wtb rear rim and hub
    I need a rear 6" wheel an hub for my trail horse. Thanks.
  3. james ackerman
    Calling all experts!!!! Grimeca brake plate and hub questions.
    Ok I'm doing a restoration on a bike and I am trying to refinish all the parts. I'm stuck on my brake plates and hubs. They look about identical to rupp but they are only 20 spoke hubs so I can't just buy those shiny new ones I find online. I'm down to refinishing them but not sure how to...
  4. CarPlayLB
    rear sprockets with hub and brake
    Hola! Como esta? I have two sprocket, hub, brake set ups. One has a 72 tooth sprocket and the other is a 60 tooth sprocket, both for #35 chain. These come with the bolts and spacers. These fit Manco and Lomart/Cheeftah wheels, and probably many others. These are new parts that have been stored...
  5. Cubenzo
    El burro hub assembly.
    I could use a set of el burro wheel hubs.. Stock or modified. Trying to get my 2 burros rolling.
  6. Karterman
    FLEXO Big Bear Scrambler Sprocket and Hub for Type 1 Go Power Wheels
    Used Flexo Big Bear Scrambler and brake hub with a new 60 tooth sprocket for Type 1 Go Power wheels. The drum/ hub has some pitting shown in the photos. $125 shipped
  7. ludicrous speed
    need a rear gearplate fits #40 chain for 3 hole hub
    need a rear gearplate fits #40 chain for 3 hole hub,the rim is off a scat cat/taiwan bike. am looking for stock ratio or something close. the model was the sc 114 im looking for new or used on the gearplate and i could use another rear wheel and a brake assembly if anyone has one too. they...
  8. Bob Gaudette
    Wanted rupp front hub 28 spoke
    Looking for a Rupp front wheel hub 28 spoke for 12 inch rim.
  9. Dr. Shop Teacher
    Adapting Drum Brake to MW 525 Band Hub????
    Has anybody tried adapting https://www.OldMiniBikes.com/4-1-2-Brake-Assembly-w-Steel-Anchor-Backing-Plate-5-8-Bore.html to a MW/Gilson Band Brake hub? The ID of the hub is 4.5" and the model referenced is 4.5". Just wondering if this might solve the lack of parts for an original band brake...
  10. OND
    18 X 8.50 - 8 Wheels, Tires and Hub Caps
    If anybody needs 1 or 4 of these I have them for sale. Golf cart wheels 18 x 8.50-8 Kendra hole n 1 tires, tread is better on some than others but they all hold air. Bolt pattern is 4 on 4 on the wheels and come with the SS hubcaps. $ 25.00 a piece plus shipping.
  11. huertagg
    TRADE: CAT rear wheel assembly (Drum brake, hub, sprocket) for 2 BONANZA RIMS
    This is what I got to trade with.
  12. Biffmini
    Trail horse rear wheel w/sprocket hub
    I'm rounding up parts for another trail horse build. I'll be needing wheels, swing arm, brake drum & band bracket. Rear wheel w/ sprocket hub is highest on my list...
  13. K
    Trail horse mini bike rear sprocket hub
    So I just acquired another trail horse but this one has 3 spoke 2 peice aluminum wheels on it. My other has steel wheels. So I got a clutch brake since I had no way to add a brake drum on the other side. Got it all together and now when it's rolling the chain goes from loose to tight I think...
  14. chrisr
    FOX SUNDOWNER sprocket hub needed
    Looking for the hub that goes between the FOX SUNDOWNER rear wheel and sprocket. The mag wheels are 10" thanks
  15. smudvapor
    Need a hub
    Looking for a front wheel hub for a 71 Scrambler. 10" slotted wheel.
  16. 2SlickNick
    MTD mud bug
    In search of a mtd mud bug wheel hub for 1" diff axle.
  17. 125ccCrazy
    ARC billet adjustable flywheel for Briggs 5hp flathead
    excellent shape... adjustable center hub... $85 plus ship
  18. PAPSTISY
    Need Axle hub help for project
    I'm looking for a 5/8 live 4 bolt axle hub. I have searched the net and could only find 1". Does anyone know where I could find a hub with a 5/8 inch bore? Could really use some help as to might have. Thanks
  19. CarPlayLB
    Auranthetic or Maverick forks
    I need the forks from a Maverick or Auranthetic minibike. These are for my Super Taco build. They used the same forks. I am also in need of the brake hub for the same forks thank you
  20. CarPlayLB
    Gemini SST 50 forks and brake housing
    I am restoring a Super Taco T100 and they shared the same forks as a Gemini. My lowers are rusted in place. I need complete forks if you have them. Also, the brake hub is different than what I have. I need the brake hub (the piece that holds the shoes) that has the cable stay built into the hub...
