jack shaft
  1. Tarslave
    Wants to lurch at idle
    I’m new. Love my new Coleman ct200u, did a little mud riding for the first time today. By the end of the ride I noticed she wanted to keep cruising while I was just at idle. Like I had to hold the brake to stop. I bought two of these machines one for myself and my wife. It’s a new hobby. I will...
  2. The BLACKOUT KiD
    Lil Indian project
    Just picked this up, Trying to find some info on it. Came with a jack shaft but not sure it’s original to the bike?
  3. Navynuke00
    Someone help
    I picked this up the other day for, and for the life of me cant figure out what it is, I have tried matching it to different tote goat frames but the fully round back bar is throwing me off, the other weird thing, ( and it may be aftermarket but idk) is it has a manual ho and low gear on the...
  4. bremerman
    WTB Skat Kitty jackshaft assy or any parts there of
    Money awaiting kind soul with parts I need. :wink:
  5. E
    gear ratio for taco with jack shaft
    need help with 1/8th or 1/4 mile gearing. i dont have the cash to buy 20 different sprocket combinations. i have a taco minibike with the jack shaft. i do not want to eliminate the jack shaft. any help will be greatly appreciated
  6. CJdoodlebug90
    Jackshaft questions
    Ok i have a modded preadator on a mtd trail flite...which is somewhat like a rupp. Mini bike has a jackshaft setup and when i got bike i had to restore it so didnt know the exact gear ratio. So...the ratio i have now is: 12th clutch, 14th jackshaft to 10th, and 60th rear sprocket. When im...
  7. K
    Where can i find a 5/8" Chrome moly jack shaft?
    Does someone make a chromo jack shaft? I have a cheapie, and apparently im working it too hard because it seems to have warped or bent. Should I just get a cold roll keyed shaft or get a solid 5/8" chromo shaft, and make my own gear stops to hold my middle gears? I ride my mini bike a...
  8. hemigremmy
    Rupp Dart - Jack shaft????
    Looking at my Rupp Dart and trying to figure out what all i would need to redo it myself, I measured the jackshaft mounting area and it is 8" outside of bearing to outside of bearing, would i just buy the jack shaft mounting kit and use all the parts there EXCEPT for the weld on tabs for the...
  9. Y
    jack shaft
    Can someone help me with a pic or? on a jack shaft how it works , trying to get mine going, Thanks
  10. jwmikecz
    clearance problems
    i pulled a tecumseh h70 off of a snowblower and it fit under my frame:thumbsup: but the thing is....its too wide. actuallly its not that wide, but the way it mounts the flywheel/recoil start side extends far out onto the right side, i can barely put my foot on the peg. the engine doesnt have a...
