Notice a difference between the nut of the old vs new for this carb kit I bought.
The one on the left is the new one and the large hole is only on one side and small idle hole directly below it. The original has two large holes across from each other and the small idle hole is about 1/4 around...
Hello,
Im currently helping a friend of mine fix up his 1984 honda z50r. We are going to be removing the flywheel with the special pulling tool from motion pro, to change the points and condensor. My question is when we put it back together...
Does any one know what the torque spec is for...
newbie question but when adding a starter nut to your crank shaft do you use it in place of the nut holding the flywheel or just add it to the end of the shaft? thanks in advance.
Today, I started tearing down my 1970 Roadster for the build-off. After a few days of soaking, the swing arm assembly finally came apart and I was able to get the entire bike stripped down except for the jackshaft. I can't get the roll pin out. I tried using all sorts of different tools to knock...
Anyone know what the thread size is? I would assume it's an M15(which isn't common) but I have no idea what the thread spacing is. Anyone know where I can get one?
