pull start
  1. S
    Coleman CT200u ex Pull start
    I recently purchased a ct200u ex used and modified it a little bit- stage 1 kit, new spark plug, new gas and oil, lubed up some parts, 18lb valve springs, new carb and carb jet. Athough recently i have not been able to start it up- the pull start will allow itself to be pulled a slight bit but...
  2. J
    Modified Stage 2 Predator 212 Hard to Pull Start and Mikuni 22mm Running Rich
    Hey all, I have a Predator 212 with a header, billet flywheel, billet rod, hot-265 cam, 22mm Chikuni from gopowersports, and 22 lb valve springs. The flywheel has 34 degrees advance timing. I just put together the engine a couple days ago, rode it for about 30 minutes, went inside, and then when...
  3. T
    Predator 212 hard to pull
    Hey, so my predator 212 is having an issue. After a day of riding it until the gas was out, I leaned it up against a tree outside, I think that there were light rains. Went out next morning put gas in it and it wouldnt pull. The motor is completely stock. Oil level is full. So there is a...
  4. Acolytus
    Honda GC160 pull start stuck!
    Well my one Honda engine was accidently stored upside down and all the gas and oil leaked out. I turned it back up right and cleaned it off as well as I could. I threw some fresh gas and oil in and but the pull start is like stuck cause it only pulls half way. I thought it was because I had no...
  5. DuffyMechanics
    Predator 212 Feels like it has too much compression
    I was just reading a post like this but it was a little different. So I put on my air filter, adapter, breather, new header and 18 lb springs, after tightening the rocker arms, I broke one and bent the rods. So I put the stock springs back in and rockers and rods from another honda clone. But...
  6. Greedy_Jayp
    WABTED Honda 6.5 GX200 pull start
    im looking for a Honda 6.5 Pull Start for my GX200..when i brought the motor it didnt have one so i have been using a rope.Let me Kno if you have one..i prefer someone in Cali ( inland empire area ) but for a low price ill go for a shipped one
  7. A
    don't now were to put the spring in the pull start
    I try to reassemble the pull start that my father take apart on his snow blower but don't no how that spring go. On the picture is how a put the spring it look to the right way but I have to put rrrreealy quick on it otherwise it's not griping.So if some one now how to fix my stupid problem it...
