just got an older lil indian roller, it has a 36 tooth 420 chain back sprocket. its in good cond. should I keep running that or change out to a 60 tooth or so larger?????? what would the difference be in top or bottom end???? thanks much for any info
Looking to buy a tav 30 on ebay. There are two kits one with a 6" clutch and another with a 6" 5/8" inner diameter Driven Clutch. Not sure if either one matters. Which one should I get for my predator 212? thanks
Hi there.
Looking for a good replacement set of tires that you can buy new that would be a good suitable replacement for the original and very dry rotted Carlisle 4.00-6 block tread tires that came new on my 1971 MTD trailflite mini bike.
If I'm correct, a new modern 4.00-6 tire is not the...
So I picked up this small custom trike. The rear currently has 13x6.5-6 tires on it, I'm looking for something a little wider and maybe taller but nothing crazy. What would be something slightly bigger and wider?
I would buy wheels and tires already mounted as the wheels I have seem to have...
Working on getting the barn find Roadrunner back on the road, there is a belt on it, worn and maybe a little long. wondering if anyone has found a good replacement belt to use for them? I did a search, no luck, I did print out the Vplex sheet from mini doodle that delray posted up years ago...
Hi everyone, I'm trying to decide what pitch chain to use on my trail cat. I'm pretty sure it was #35 org,But it seams to me that #40 would me more suited to the weight of an adult rider and increased power output, Any thoughts? Steve.
I'm redoing 2 acro's 1 is a hard tail and 1 is a soft tail. The hard tail came with the incorrect seat and the soft tail I only have the brackets. Does anyone know the proper length of seat I need to get for both? Just want atop get the as close to what they should be without guessing. Thanks Bryce
I have a question on actual size of the Gemini SST80 vs. the SScat (saxonette 50).
My soon to be 14yro son is looking to up grade to a bigger bike. Ihave the opportunity to pick up a Gemini SST 80 for $350
but if it's not bigger in size than the SScat it wont do me any good.
On my carter kart, I'm installing the new chain , had to shorten it but I realized I prob need a half link. Of course for the RLV extreme performance chain they don't make them.
So, if I adjust the jackshaft to take out some slack, the driven pulley will move affecting the belt for the 40...
I sold my tote gote mini gote a while back and just yesterday I got a call from the new owner.
He said he loves the bike, but wants to get a replacement belt for it. I believe the belt that was on it was the original one. While I had it and rode it I noticed the belt was slowly...
Hi all,
Looking for some info on what size clutch brake band to go with.
I measured my clutch drum at 4.25" diameter and not sure how to size the band.
Here is a pic of my 400x.
Thanks.
Hello have a Sears/tecumseh motor and need help with cross reference to find out what size hp it is the numbers are 143 644032 serial# 3234B . Any help would be greatly appreciated. :thumbsup:
Does anyone know the size of the two spacers used on the rear wheel? I figured I would make them myself but im having a hard time finding their size. Mainly the length. Any help would be appreciated. Thanks!
I posted about this before on the brakes of my mini bike. Is there a way to tell what size brake pucks I need without taking them apart? I took a few photos, thanks
Hi guy
Just got a Baja doodle with a predictor hemi 6.5 hp. The mini has a 72 inch sprocket on the rest. The bike got tons of torque but ar half to 3/4 speed sakes like hell. I like to cruse atound 20 mph but it's shakie there . Can I switch to a smaller rear sprocket to get the rpm down some...
