stumped
  1. Dr. Shop Teacher
    I'm stumped: 3hp no start
    This is the engine for my build-off bike. The engine will not fire. I got one backfire with starting fluid and another one ignited fuel vapors coming from the tank cap (never had that happen before:doah:). Here's what I checked: 1. Spark--hurt when my hand got too close to the spark tester, so...
  2. Dr. Shop Teacher
    I'm stumped on this one...
    On CL in Richmond.
  3. J
    I'm stumped!
    I'm asking for your help! I picked this up as part of another deal, but I cannot figure out who the manufacturer was. It may be a cobbled together Frankenbike, but I'd be happy to just find out who made the frame. Some knowns: 1979 Briggs 3HP 80202 / 0016-01 (code 79050201) Mounts for...
  4. gran_pann
    honda gx620 carb, im stumped!
    Hi everyone, I have a GX620K1 engine (QZB2, GCAD) the 2XXXXXX serial number I have been trying to figure out what a certain hole in the carb is for and im stumped. I can see the fuel inlet, bowl drain outlet, and then there is this spot at the top that had some cut off hose running to it. I...
  5. J
    stumped
    someone mentioned it's a bird, i'm stumped
  6. motomonster212cc
    still stumped on hooking linkage up....
    sooooo... I'm trying to figure out a way to my throttle cable to the Tecumseh carb I have. I was hoping someone else here has been through this in the past and can help me out. thanks for any help I get, Lyle
  7. L
    Stumped with new project.
    Been able to identify every mini I've had till this one, any guesses. I'm thinking at least one wheel and the seat may not be original and can't see any remaining original colors under the thick red paint.
  8. D
    Briggs 6.5 vertical shaft
    Okay, I'm stumped. It's not for a mini, but I know you guys can help. I've got spark. It will run when I prime it (or on starting fluid), but it dies shortly after. I have cleaned the carb vigorously two times. There is no leak between the carb and block, and I know the main jet is clean because...
  9. Iron Honky
    Stumped
    Anyone ever see this one?
  10. 7
    stumped on this purple mini
    what is she?? and whats it missing or wrong.
  11. SimpleTom
    On ebay right now and I'm stumped
    Anyone have a clue? :shrug:
  12. nscard
    This one has me stumped
    Hi all, This little machine has no markings on it. It has front and rear drum brakes and all appears correct and original. The 3.5 Briggs dates to 1964. Any input would be helpful. Thanks:shrug:
  13. Mac
    Stumped Again....What is it?
    Looks a bit like Arco, but only a single downtube up front. I don't know. A friend told me $20, I told him I'd think about it.
  14. B
    Stumped
    Flojet carb on an older 4 HP Briggs. Engine sat for many years. Installed new points and set @ .020 and coil/flywheel @ .010. Rebuilt carb with OEM kit with updated needle and seat. Engine sputters with both adj. @ 1 1/2 turns out. Engine runs beautiful with mixture screw out of carb...
  15. L
    Help stumped
    I'm in the middle of getting this old mini-bike going again. I have not a clue on the make or age? I've searched everywhere and looked at many photos with no luck. Any help would be appreciated. Thanks!
  16. J
    Stumped by Flo-jet Carb
    Have a late 60's early 70's 80300 series B&S with the 2-piece flo jet carb. Trying to get engine running but having trouble with carb. Have installed rebuild kit and new float. Problem is that when bowl is empty and I turn on fuel from tank the engine starts and runs until it appears to flood...
  17. mmisterbungl
    I'm stumped - what is this
    I've seen this bike but can't seem to find what it is right now.
  18. W
    My Newest, but Im stumped as to what one?
    I picked up this Rupp tonight. The guy I got it from said his dad worked at Rupp back in the day and he had a couple laying around from when he was a kid. He was not sure what model this was, but it did come with the 12" rims. To the best of my knowledge only the Black Widows came with those...
  19. TacoKid
    Its Got Me Stumped
    Scored this with two bearcat twisters...
