‘71 sears roper one way sprocket
Can anybody tell me where to look for a one way sprocket/over run clutch with sprocket for my ‘71 sears roper? I’m trying to get the two speed set up on the jack shaft and need a 5/8 bore 24 tooth #35 over run clutch with sprocket or a one way sprocket.
Triley41395
Ignore the post above mine, it's just spam and will be removed. As for the sprocket, I'm not sure where to get one. If I were you and you have a hard time finding one I would just use stationary gears so you can ride it while you look for the correct 2 speed parts. You might contact Hent.com at the top of this page, he may have something or possibly point you in the right direction.
