Hondapowersportsoftroy dot com is a site that will get you the correct part number through the honda parts network. It is actually cheaper to order stuff online and then pick it up in the store. there should be other honda dealers that sell online as well. There are motorcycle forums you can join that have free online manuals that you can download for Hondas. You may need to get a manual to correctly set the height of the new floats that you are purchasing. I definitely recommend Honda brand or OEM [mikiuni] OEM parts for carbs. A bad experience with after market carb stuff is likely.
When I got my Honda twin,the carbs were glued tight with hard brown varnish. It is a 70-80 MPH machine now. 150 for the bike and 70 bucks got it running.
Since this is a mini bike forum,I will also mention that Honda four stroke road motorcycles need a good fresh battery to run even if you kickstart them. It is called battery on coil ignition, and many people make the mistake of trying to get by on old weak batteries.
