I am working on a TrailBlazer with the 2 speed, the secondary clutch says Comet. The primary I have not had off yet but believe it to be Comet as well. Engine is Tec HS50.
Will be replacing the 2 short chains tomorrow.
My concern is that the primary clutch floats on the engine shaft and did not have the set screw installed. Also it can float all the way to the engine case. However it does not appear that it has done that too much as there are no big gouges into the side case.
Should this clutch have machine washers behind it to keep it from wandering in that far?
Or is it made to just align itself with the jackshaft sprockets on it's own?
The one way sprocket seemed to have a little glitch when turned by hand in the freewheel mode and I was able to work some motor oil in behind the outside dust plate and it seemed to smooth out so that is good.
Bearings are very good on the jackshaft with no play and the sprockets all look good with no major teeth wear.
Thanks for any guidance.
Later,
Keith
Later,
Keith
