If you want it bolt on (with shaft) you need to remember to look for a long shaft with some extra length on both sides for the General appliance bikes, Not a big deal deal as they use a standard 5/8 shaft but the true comet ones had notch cuts for C clip retainers to hold the one way first gear and the 2nd gear clutch assembly. The shaft off a Gilson 2 speed is is long and good for them if you can find one.
I have some NOS and very slightly used comet 2 speeds coming available soon, I am really behind right now on getting things cataloged, photoed, researched/priced, and listed right now though so it will be next couple of weeks. I think blackwidow might have comet 2 speeds available as well as the repro maxtorque one that was linked above, pretty sure they are or were short shafts, at least he used to.
