Thanks for the comments folks. I took the photos because it was time for my monthly update, and aware they're pretty ugly, and don't show what's going on. :laugh: I did a lot of other things with the bike as well, fabrication-wise.
Yesterday I read several posts from Powell restorers on getting the front forks apart. Thanks to that information, I was able to do that this morning, although I have to admit it wasn't as easy as all that. I used a half-copper pipe to nudge the top bushings down enough to get at the "snap ring," which is a piece of .032 spring steel wire. It doesn't come easy, then suddenly it's in your hand.
Six inches down into the tube is another bronze bushing. I used a blind bearing puller at an angle and it took a lot of whacks with the slide hammer to get it out. I don't know how you'd get this out without that tool, unless you cut it with a bare hacksaw blade. (Bad idea) That bushing retains a longer spring with a washer between. You "could" send it out to chrome with it all together.
There is also a welded steel collar on the lower, which is 5" from the end. That needs to be removed, so the chromer can get around the smaller spring and bushing it retains. (This boring information is for my own edification when I reassemble it)
Side note: The theme of the bike would lend itself to lowering it slightly. I'm thinking about bringing the lowers up one inch by extending the steel retaining collar an inch on reassembly. Then I could cut an inch off of that nice powder coated rear spring I got off of mini bike paul.
Please vote for me, because I need cheap parts from Hent for the next stellar build. :thumbsup:
