I ordered seven "6203 2RS Double Sealed Bearing 17mm x 40mm x 12mm" bearings from Ebay. Perfect fit and replacement for the Powell wheels, the two in the driven pulley, and the one in the belt tensioner. Tensioner shown below before welding. I had to separate it to get the pulley out. By the way, the same place that sold the bearings, also had the B31 belt and I got that as well.
Other parts on order:
Woven brake lining, as used on Model T transmissions, and JB Weld high temp 8280 for the adhesive.
Also, 428S tail light, and universal spring activated brake light switch. Once I have these, I can fabricate a replacement mount for them, as the original was cut off.
