Hi guys! Thanks in advance for any helpful ideas!
When I rode the Baja around I noticed a really bad vibration at a certain rpm. I'm guessing I'm doing about 15-20mph? That's a guesstimate.
I took off the jack shaft chain to isolate the problem from the suspension And chains (in case they were loose I I don't have a chain tensioner on the jacks haft chain-gone when I got the Baja) and the vibration appears to be from the engine.
To make sure it isn't a loose engine plate like the welds broke I pressed down on the engine with my foot and the vibration didnt change.
Below is a video. I start the engine at idle then gradually increase the revs.
6.5 hp clone engine, vibration at certain RPM. - YouTube
At 5 seconds revving up then 25 seconds coming down off the revs one can notice the gas tank shaking( I need to fix the rear mount!) and can hear the engine rattling. Once at that RPM where it vibrates if I rev more the engine smooths out.
Is this a normal vibration at this RPM? Just ignore it?
The governor linkage was removed by the previous owner. You think the internal governor gear and weights are doing this?
I figure if it was a crank or cam bearing it would continuously vibrate and get worse as the RPMs increased, yes?
The previous guy replaced an intake valve that snapped. Just extra info.
Thanks!!!!
Thanks!!!!
