Hello,
Short update on the projects;
Some more parts have arrived and others are on their way.
Both minibikes will be equipped with torque converters, so now I have 2 at home. In the background (on the box) is 1 of 2 seats, that we'll be using.
Both minibikes will be using thumb throttles. These aluminium throttle housings came for €4,-/each.
I'll modify them to make it more comfortabel to operate. And to meet my quality standards.
They standard Chinese clearance/play on the shaft is resulting in poorly behaving and sticking throttles.
I'll replace the cast aluminium shaft with a stainless steel one (cut off part of 14 mm bolt). And with a reamer I'll make the housing bore 16 mm. In the housing I'll place some thin wall sliding bearings. They will not misbehave themselves anymore...
For a total of €6,- (=approx $7,-)! I have ordered, all new, quality, hardware for:
Cylinderhead studs + nuts
Side cover studs + nuts
Valve cover studs + nuts
Exhaust manifold studs (SS) + brass washers + brass nuts.
Intake manifold studs + nuts
And a new M14x1,5 nut for the flywheel.
"Stay tuned"
"Stay tuned"
Concerning the number of bikes...
It takes one to ride, two bikes to race, and three for the future “group ride”.
Fine work on parts received!
