Got this bike as just a frame with the other 2 arco choppers I bought and I'm chopping this one up so a full size adult can fit on it. Plans are stretching it 5 inches. Get rid of the sparkle banana seat since it hurts my ass. New foot pegs, engine plate, swing arm and shock mounts.
The forks are bad looks like it was straightened with a hammer. So I'll build new ones that look stock but are wider to fit a larger tire.
The tires/rims I'm using are 6 inch steals 5 inch front and 6.5 rears.
For the engine I'm not sure I have on hand tecumseh h35,hs40, hs50 and predator6.5 will be using a jack shaft.
So far I cut the frame apart and made extensions for the frame out of thick 7/8 tubing milled down the end 1 inch so it acts like a slug and tapped it into the frame ends.
