Azusa Drum Brake Hardware
I did a search on this and didn't really come up with anything that could help so here it goes. Maybe this will help on future searches as well.
I got my drum brake assembly and of course there is nothing that connects the cable to it. I've seen some great pictures of how it's set up with the spring, cable stop and step retainer. Now I look on the warehouse website and there are 5 springs, as many step retainers and a ton of cable stops. My question is, what part works?
Bob
old-timer
Scamming Member
Lol I'm having the same issues Bob:shrug:
Working on my build off bike and I ordered the same set up, but now I need all the hardware to hook it up. Hopefully someone here will point us in the right direction.
Vic
Hent
New Member
The 4-1/2" :
https://OldMiniBikes.com/4.5-Brake-w-Anchor-Backing-Plate.html
https://OldMiniBikes.com/4.5-Brake-w-steel-Baking-Plate-AZ2270s.html
Both take https://OldMiniBikes.com/Wire-Swivel-w-Screw.html to connect the cable to the arm.
The 5" INTERNAL DRUM BRAKE - AZ2530
AZUSA makes nothing to attach the cable to it. You'll need to make something. I'll sometimes use a bolt and drill a small hole through it for the cable to pass and then use any type of wire stop to hold it in place.
Maybe someone has a picture of the Bonanza brake pieces that work nicely with this?
old-timer
Scamming Member
The 4-1/2" :
Thank you Hent :thumbsup:
Vic
