So a little more on the bracket is that angle is a little past 90°.... Probably 105 maybe. Also, there's a shorter hole a little up the bracket for the drum plate bolt to fit at an even wider angle like about 135, which would nearly hide the whole assembly behind the swing arm... But I'll be giving this fitting a few rides before trying the wider angle setup.
