Before I try the ball bearing thing the one handle bar is half way full of rust or some thing. I was using the drill snake and it broke off in the bar. Lol. Now I'm screwed. Lol
Karen, under the circumstances I believe I would take a piece of 1/2 inch angle iron and scribe a straight line down both fork tubes and just cut them off about 1/2 inch above the top fork plate. You can weld them back together and use the scribe make to index them correctly. I think any other route will just consume time and still result in cutting them off anyway....
Its what I would do after all the time and trouble that has been spent trying to remove the parts in a non destructive manner.... :grind:
Doug
Edit - More than likely the tubing will be so bad from the rust that it might just give up and rupture once you get the pieces to move... I know this guy named Eric that can bend tubing real purty.... :anon.sml:
