Bonanza CR500 Hodaka Chopper Throttle/Cable Question
dwarfbike
Does any one know what throttle and cable the Bonanza CR500 Hodaka Chopper came with? My Hodaka has a Hodaka Throttle Cable but the ball on the end of the cable is to small for a standard mini bike throttle. Trying to figure out if I need a different throttle or new to swap out the cable. Any tips will be helpful. Thank you in advance.
Hi Dwarf bike, did you find out a source for your cables? I'm building one now and same issue came up. Unsure if OldMiniBikes has right or need to have custom cable made. Thanks
I74
Bet that ''cool @$$'' chopper is fast as hell,, & a real hand full !
Can you even take off at all on it in first gear, & keep the front end down ??
Bet you also gott'a lean forward pretty good regardless.
Rode a ''beautiful'' Hodaka Super Rat back in the day with the Ace 100,, & it was ''real quick'' & fast !
Those were always my all time favorite dirt bike, & still are.
That chopper is something else, & would love to try one of those out,, given the chance. :cool:
I’m running an Ace 100 on my BC1500SH not on my Chopper. 1st gear is super low (1 up and 4 down) but once you get into 2nd and 3rd, then the power comes on!
I use mini bike cables, then solder on an end for the Mikuni-usually three times to get the distance right between the top of the carb where the clamp is, and just enough tension to get a good return. I use 1/8 brass rod that I cut and solder on to the cable.
I think the 9-18 tooth sprockets are just too low for these.
I74
Boy,, I'd love to ride one just to see where it likes it.
