I am in the process of restoring some Briggs & Stratton three and four horsepower motors. I am replacing the old breaker, points, condenser ignition systems with electronic ignition modules. I'm wondering how to approach the hole left where the old points plunger was held. The way I see it I have several options. 1. Remove the plunger and leave the hole open. 2. Remove the plunger and seal the hole with gasket sealer or heat resistant RTV silicone. 3. Let the plunger in the hole to float up and down. 4. Let the plunger in the hole and seal around it in the up position with gasket sealer or RTV silicone. I would be curious as to how those of you who went to an electronic module have dealt with this issue. Thanks, Ogy
